| Turtle!! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=73433 |
| Author: | duc killer [ Thu Jan 10, 2019 5:00 pm ] |
| Post subject: | Turtle!! |
I’m running a stock 35 mudbuddy on a 16’x44 gator trac. Wondering what speeds I should be getting. When I have just me and my son I still not moving like it seems like it should. Any help is appreciated. |
| Author: | Wchauvin [ Thu Jan 10, 2019 5:09 pm ] |
| Post subject: | Re: Turtle!! |
I would guess you would be running around 22-26 with you and your boy and a very small load. What speeds are you getting? |
| Author: | duc killer [ Thu Jan 10, 2019 5:11 pm ] |
Man about 16-17 max. |
| Author: | Wchauvin [ Thu Jan 10, 2019 8:01 pm ] |
Long transom or short transom motor? Height of your transom? Rpms you are turning at best speed? |
| Author: | 50fps [ Sat Jan 12, 2019 7:52 am ] |
How much junk in the boat, how fat are you and your son? To many variables to give a guesstimate. |
| Author: | duc killer [ Sat Jan 12, 2019 5:20 pm ] |
Short transom. 13”. I gps yesterday and today. Yesterday me and buddy probably close 480 lbs deeks guns and gear with wind 16mph best I could do. This morning me a different buddy and my son and gear never got over 12 mph. |
| Author: | duc killer [ Sat Jan 12, 2019 6:16 pm ] |
Any help on what I need to do would be great. Not sure how much new prop would help. Muffler Card kit. Just need to move a little better than I am. Thanks!! |
| Author: | bluesky2012 [ Sat Jan 12, 2019 6:18 pm ] |
| Author: | duc killer [ Sat Jan 12, 2019 8:50 pm ] |
Don’t know what valve lash or leak down is. |
| Author: | duc killer [ Sat Jan 12, 2019 8:52 pm ] |
Prop measures 12” |
| Author: | brycecheramie [ Sun Jan 13, 2019 6:47 am ] |
What are your rpm's loaded and unloaded? That's where we need to start |
| Author: | duc killer [ Sun Jan 13, 2019 7:18 am ] |
Unloaded 3160 Loaded 2955 |
| Author: | brycecheramie [ Sun Jan 13, 2019 7:24 am ] |
| Author: | bluesky2012 [ Sun Jan 13, 2019 7:44 am ] |
| Author: | Russ [ Sun Jan 13, 2019 7:59 am ] |
| Author: | bluesky2012 [ Sun Jan 13, 2019 8:03 am ] |
| Author: | brycecheramie [ Sun Jan 13, 2019 8:28 am ] |
| Author: | bluesky2012 [ Sun Jan 13, 2019 8:44 am ] |
| Author: | duc killer [ Sun Jan 13, 2019 12:15 pm ] |
Motor is 2010 |
| Author: | brycecheramie [ Sun Jan 13, 2019 12:21 pm ] |
| Author: | Will C [ Sun Jan 13, 2019 12:29 pm ] |
Surprisingly there are still some non cdi motors being sold. I've seen this when guys buy the cheaper motors online when the model number doesn't quite match. Seen some weird carburetors too. Some aren't even made to idle. Aside from all this I think your motor is weak. It needs a health check soon |
| Author: | duc killer [ Sun Jan 13, 2019 12:43 pm ] |
Just says hyper drive. Wish I meme how to post pics |
| Author: | bluesky2012 [ Sun Jan 13, 2019 12:53 pm ] |
| Author: | duc killer [ Sun Jan 13, 2019 1:02 pm ] |
It’s not marine. |
| Author: | duc killer [ Sun Jan 13, 2019 1:06 pm ] |
Text me and I will send u pic. 731-676-9728 |
| Author: | duc killer [ Sun Jan 13, 2019 4:15 pm ] |
If I put a new prop how much more speed will that get me And what kind is best. Also if I can find someone Around here who knows ends and outs and what to look For what should I tell them to look at. Most everyone I come across just do service work for Briggs. They Don’t really know much about how one is supposed To be set up. |
| Author: | bluesky2012 [ Sun Jan 13, 2019 6:12 pm ] |
| Author: | Wchauvin [ Sun Jan 13, 2019 7:50 pm ] |
Send it to Marcus or will c and get what you want bro and be done with it |
| Author: | banded-mallard [ Mon Jan 14, 2019 5:21 am ] |
too many factors other than prop. - valve lash set correct - valve leaking by, thus loosing power, thus slow boat. - worn prop ( but correct by blue shy, worn prop = more rpms) - does your hull have any hooks? meaning does the bottom of your hull look like a lays potato chip - carb adjustment. If stock carb, one jet could be partially plugged. Have seen this and will run like a top out of water, but once under load, will basically only be hitting "great" on 1 cylinder. - Is your throttle cable set correct. the butterfly or slide (mikuni) may not be opening up all the way - governor set correct correctly I had a 2007 and if I remember correctly, 2010 was the first year that the CDI engines came out. I have a 2010 at my house right now that is CDI and it doesn't say marine on it. Wasy way to check is to take a pic of the coils. They will look totally different that the non-cdi engines. |
| Author: | duc killer [ Mon Jan 14, 2019 6:20 am ] |
3860 out of water |
| Author: | brycecheramie [ Mon Jan 14, 2019 6:39 am ] |
| Author: | duc killer [ Mon Jan 14, 2019 6:47 am ] |
What should my rpms be? In and out of water |
| Author: | brycecheramie [ Mon Jan 14, 2019 7:00 am ] |
| Author: | duc killer [ Wed Jan 16, 2019 11:55 am ] |
I appreciate all the help and advice. No internal Motor issues. Spring was not letting governer open All way up. Seems simple but for a carpenter it was Just like trying to read Chinese. Thanks again for All the help I’m sure I will be back soon as I’m looking To add just a few performance parts to help out a little More. |
| Author: | bluesky2012 [ Wed Jan 16, 2019 12:03 pm ] |
