It is currently Wed Mar 18, 2026 1:36 pm
[ 8 posts ] |
JBsuperG
Joined: Wed Mar 21, 2018 2:51 pm Posts: 263 Location: Michigan
 results from new heads
I just installed new heads from Will C on my MB 35. It already had a mikuni carb. The motor sits on an Alweld 1648 with a hunt deck. So far I have only been able to test it out with me, my blind and a light load.
The difference that I was able to see without much of a load was minimal. My RPMs at WOT went from about 4100 to 4400. Top speed went from about 27 mph to 28-29 mph. I am running a big blade without any work done to it. I have one on the way from Baggy. It should be here next week sometime.
I was adding this mostly to help with larger loads (although usually it is just a two man load). I was hoping to pick up more than a couple mph. However, If I can plane out with three guys, my 90 pound dog, and a hunt load I will be very pleased.
| Sat Dec 29, 2018 5:39 pm |
bluesky2012
 Re: results from new heads
You will feel a healthy difference in load carrying. That’s the really dramatic benefit I found quickly with mine when I installed marcus’ heads on mine with a stock carb and stock exhaust.
| Sat Dec 29, 2018 5:56 pm |
Buzz Killington
Heads woke my motor up. Quite happy with the load carry on a 1760 and 18doz decoys hunt gear and 3 of us. Will C makes them good Support your troops. We support you. B.
B. MacDonald
| Sun Dec 30, 2018 5:13 am |
Will C
Not bad but thats on the lower side for that setup. Holler at me sometime, let's talk tuning
| Sun Dec 30, 2018 1:20 pm |
JBsuperG
| Sun Dec 30, 2018 2:12 pm |
JBsuperG
Although it was a cold rainy day yesterday, I had a couple friends who still wanted to go for a ride.
3 guys (200+ each), a soaking wet blind, hunt load, 90 pound dog, and a couple gallons of rain water. Before the new heads it would not plane out. I was able to get on plane with this load now. I'm not sure of my speed. if I had to guess I was probably going 22. It probably took four boat lengths or so to plane out.
Overall I am happy with the improvements. I am sure it will only get better with a worked prop.
| Tue Jan 01, 2019 10:19 am |
Wchauvin
Run it empty and loaded and get rpms at best speeds, send your prop to baggy, and you willl see good results
| Tue Jan 01, 2019 6:59 pm |
JBsuperG
I had a chance to run it with a worked prop.
With a lighter load that consisted of my blind, couple dozen decoys, me, wife, and 2 boys (about 500# of body weight) I was able to hit 29 mph. I am not sure about RPMs. It was to dark to see my tac.
The following day I was going to run it with just me and the blind, but my younger son wanted to go for a ride (couldn't tell the little guy no). He is only 65#, but I figured if he is going I would bring my dog (90#s). The speed still maxed out at 29 mph 4400 RPMs.
I think when it is just me and I have the blind removed it will hit 30 MPH. That won't happen anytime soon though. The river has started to freeze over and temps only seem to be getting colder.
I am still really happy with the improvement Will C's heads gave me. Before that the boat topped out at 27 MPH with nothing but myself in it. Carries a load a TON better.
| Tue Jan 15, 2019 1:06 pm |
[ 8 posts ] |
