It is currently Tue Apr 23, 2024 11:54 am
Reply to topic  [ 11 posts ]
 Mikuni carb on 20 kohler
Post Mikuni carb on 20 kohler
I was wondering what would be the cheapest yet efficient way to mount a mikuni carburetor to my kohler command pro 680 20 1/2 horsepower. I have read that mounting a double barrel intake to an adapter is a general practice but is there any way to mount it's my stock intake? And how would the the throttle cables hook up? And I've been looking at 34 mm mikuni flat slide carb would this be around the right size I would need?
Thu Jan 17, 2019 12:10 pm
Post Re: Mikuni carb on 20 kohler
You'd have to build an intake adapter. 34 seems a little big, that what they ran on the 27's.
Thu Jan 17, 2019 8:10 pm
I keep reading something about a put adapter. Do they make something along this lines for the flange type Kohler has?
Fri Jan 18, 2019 8:53 am
I’ve never seen anyone here modding one of those. You should probably hit up some kart sites, though that engine may be a little big for those and a little small for tractors. Anyhow, those type of sites are where you should be looking.
Think you’re going to have better luck finding a modded stock carb than an adapter for the mikuni. If you are hell bent on running a mikuni, you’re probably going to have to do the fab work yourself.
Fri Jan 18, 2019 10:09 am
Check with Al at PVT. Never know
#TheGhostBoat
Fri Jan 18, 2019 12:57 pm
Fri Jan 18, 2019 2:49 pm
Performancevtwins.com
#TheGhostBoat
Fri Jan 18, 2019 8:01 pm
I never could get ahold of him, lol. I found a local guy in sc to go pick stuff up for me and ship it. Even better that I could send him paypal instead of having to mail Al a check which added another week to the already delayed process. :lol:
Fri Jan 18, 2019 9:16 pm
Well I found these https://www.ebay.com/itm/2Pcs-Motorcycl ... 3157151956 I was thinking maybe I could slot the holes with a2 45 degree slip to slip boot, for the height(rather than 1 90) and it would work? Thoughts? The hole to hole on Kohler is 3 3/8.
Sat Jan 19, 2019 9:57 am
Well after much tedious work this is what I ended up with, making my own.
Sat Feb 09, 2019 7:47 pm
[youtube] https://youtu.be/hDxE5EMzMPM [/youtube]
Sat Feb 09, 2019 8:03 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 204 guests
