It is currently Thu Mar 19, 2026 12:31 am
[ 3 posts ] |
Trim motor part for 2016 35 MB
fatduckboy88
I believe the trim is going out on my 2016 35 MB. I’m having to tap on the unit to get it to work. Was told it was to motor on the unit. Does anyone have the part number for the motor.
| Sun Feb 03, 2019 10:39 am |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
 Re: Trim motor part for 2016 35 MB
Check the relays first.
Sent from my SM-N950U using Tapatalk
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
| Sun Feb 03, 2019 11:19 am |
DENNYEDWARDS
Joined: Sun Aug 09, 2009 12:50 pm Posts: 574 Location: Muscatine, Iowa
Might take the motor off pump, and take it apart, sometimes motor gets water in it. We use Brake cleaner to flush water out and blow it out with compressed air. Then try motor before putting it back on pump. While motor is apart .check for loose Magnets in motorcase. If any are moving around you can sometimes reglue them with a good epoxy cement. Reseal all openings on motor with good RTV cement. If you can't get motor to work you can get a replacement from DB Electrical.
| Sun Feb 03, 2019 2:00 pm |
[ 3 posts ] |
