It is currently Mon Mar 23, 2026 9:36 am
Reply to topic  [ 3 posts ]
 Trim motor part for 2016 35 MB
Post Trim motor part for 2016 35 MB
I believe the trim is going out on my 2016 35 MB. I’m having to tap on the unit to get it to work. Was told it was to motor on the unit. Does anyone have the part number for the motor.
Sun Feb 03, 2019 10:39 am
Post Re: Trim motor part for 2016 35 MB
Check the relays first.
Sent from my SM-N950U using Tapatalk
Sun Feb 03, 2019 11:19 am
Might take the motor off pump, and take it apart, sometimes motor gets water in it. We use Brake cleaner to flush water out and blow it out with compressed air. Then try motor before putting it back on pump. While motor is apart .check for loose Magnets in motorcase. If any are moving around you can sometimes reglue them with a good epoxy cement. Reseal all openings on motor with good RTV cement. If you can't get motor to work you can get a replacement from DB Electrical.
Sun Feb 03, 2019 2:00 pm
