| 35 main bearring http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=73575 |
| Author: | Deeguy [ Sun Feb 17, 2019 6:10 pm ] |
| Post subject: | 35 main bearring |
Does anybody have he part number for the main crank bearrings/ bushings in the crank cover or a 35 vanguard? I’ve looked in the parts manual and can’t make out what’s what I’m it. Mines showing a little brass and wanna change it while i have it apart, any info is appreciated |
| Author: | banded-mallard [ Mon Feb 18, 2019 6:36 am ] |
| Post subject: | Re: 35 main bearring |
Ah...... you sure you want to do that? Hell I didn't even think it was this much |
| Author: | MaXXis85 [ Mon Feb 18, 2019 7:43 am ] |
You cant purchase the rear bearing. You need a new cover, You can only service the front bearing. It is $250 ish You also need a special tool to service the front bearings. |
| Author: | Deeguy [ Mon Feb 18, 2019 9:06 am ] |
Well shit. That’s not what i wanted to hear. Y’all agree it most definitely needs replaced though? |
| Author: | MaXXis85 [ Mon Feb 18, 2019 9:45 am ] |
Ive seen them way worse. Its from too much belt tension, and also removing the crankcase cover with rust on the end of the crank. |
| Author: | Deeguy [ Mon Feb 18, 2019 12:53 pm ] |
Yeah.., Guilty of both. Lesson learned tho. Just ordered a new cover for 250$. I appreciate the info! |
| Author: | ghillie_55 [ Mon Jun 10, 2019 1:37 pm ] |
| Author: | ksgoosekillr [ Tue Jul 09, 2019 1:51 pm ] |
if you find someone with a trashed cover but good bearings you can have a engine shop swap out the babbit bearing. BEEN THERE, didnt go too bad actually just found someone with a cracked cover and and good bearing. |
| Author: | vertical_edge_800 [ Thu Jul 25, 2019 6:19 pm ] |
I found a whole short block on eBay a while back brand new for $500... I end up just getting that instead of replacing bearings. Couldn’t believe how expensive they are! |
