It is currently Fri Mar 27, 2026 10:58 am
Reply to topic  [ 8 posts ]
 35 hp gator tail oil cooler leaking
Post 35 hp gator tail oil cooler leaking
Just bought a used gator tail 35 hp and when running noticed the oil cooler dripping oil. It was much maybe a few drips all day of running just want to know if this is normal or do I need to replace?
TIA!
Thu Mar 14, 2019 1:40 am
Post Re: 35 hp gator tail oil cooler leaking
It's not normal. Whether you choose to replace depends on your tolerance for dealing with oil leaks. I'd personally want to fix it.
Thu Mar 14, 2019 5:50 am
Thu Mar 14, 2019 6:19 am
Where is it leaking?
Partstree.com to get the part number. Order from wherever you want.
Thu Mar 14, 2019 7:07 am
Thu Mar 14, 2019 7:13 am
I know what the oil cooler is. Is it leaking at a connection, the tube through the fin, etc?
Thu Mar 14, 2019 9:25 am
No it is leaking from the actual oil cooler. Almost looks as if it’s pushing thru. Maybe has a slight hair crack?
Thu Mar 14, 2019 2:27 pm
Then just order a new one and pop it on.
Thu Mar 14, 2019 2:52 pm
