It is currently Tue Mar 31, 2026 7:01 am
[ 4 posts ] |
Ztheriot
 Performance Mods
Does anyone know of any other websites besides backwater performance to order parts from (cam, heads, pistons, etc)? I have a spare 35 Vanguard that id like to experiment with and I would like to piece it together myself not just buy a kit. thanks for any info.
| Wed Mar 06, 2019 1:57 am |
GNSPEED
 Re: Performance Mods
Will C or Marcus (Bayou surface drive) on here,Willey fast,Delta performance,Performance v twins,there is a bunch more.
| Thu Mar 07, 2019 6:39 pm |
MaXXis85
problem with piecing together a kit you know nothing about setup. valve events should match cylinder heads to some extent. Making sure the valve geometry is correct for the valves/ cylinder heads you choose. Ordering parts and slapping them together without measuring clearances, actual compression ratio, and the correct assembly process is a recipe for disaster most of the time. If you want to experiment I will suggest learning as much as you can. Sure these are similar to auto engines, BUT we do not have regulated cooling systems so CR to fuel type isn't the same. My advice is to try things, and learn from your mistakes. You will get there but it takes time. mix matching parts can work, IF you actually "BUILD THE ENGINE" don't just assemble it. ALSO make sure the tuneup is RIGHT.
| Fri Mar 08, 2019 6:04 am |
Roostertail3
Joined: Sun May 22, 2016 10:32 am Posts: 334 Location: Middle ga
Order a level 3 kit from delta performance and install yourself. It’s pretty straight forward if you have any mechanical aptitude.
| Fri Mar 08, 2019 2:28 pm |
[ 4 posts ] |
