Re: Check Engine Light on GTR 37XD
The oil level sensor if it even has one will not set a code. Other common codes are crank sensor noise and high/low charging voltage. Make sure batt cables are tight at battery and check connections at motor side. If your around anyone that can talk to that computer have the code pulled. It will stay stored in there for a little bit
