It is currently Sun Jun 16, 2024 10:01 am
[ 4 posts ] |
32 Vanguard Carb Question
Gate_Keeper
Can someone help me with a parts # of a Carb kit for a 32 hp Vanguard or a Nikki replacement?
Thanks JD
Thu May 09, 2019 1:23 pm |
50fps
Re: 32 Vanguard Carb Question
Find yourself a 36 carb, I'm sure someone has a take off from a mikuni swap.
Sun May 12, 2019 6:43 pm |
Russ
The mikuni tm36 is a good size carb for a stock or mild headwork on a 35/36. Should be fine on a 32 as well. The jetting isn't the same as the 42hsr, so PM me if you go that route and I'll let you know what jets to go with. Get the intake adapter if necessary from performance vtwins. Not sure about sourcing a throttle cable.
I cant speak to the stock 36 carb, but 50 doesnt give bad advice, so I'd trust him on that.
#CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor
Sun May 12, 2019 6:48 pm |
cb5331
The stock 36 will fit and is better than the stock 32 carb. Someone probably has one you could have for free.
We ran a modded stocker and then an hsr on ours.
Mon May 13, 2019 8:50 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 246 guests |
