How long a fuel line will a 40efi fuel pump pull through? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=73774 |
Author: | Buzz Killington [ Wed May 01, 2019 9:35 pm ] |
Post subject: | How long a fuel line will a 40efi fuel pump pull through? |
I'm looking to relocate my fuel tanks to the front of the boat, but before I run 20ft of line, how well do these 40 efi ful pumps pull through a 3/8 fuel line? I'll post a pic of how I plan to run it, but itll be roughly 20ft of total line with an abrupt 9" rise from tank to gunnels then 14ft run to the motor. Pics to follow. Support your troops. We support you. B. |
Author: | Wchauvin [ Wed May 01, 2019 10:35 pm ] |
Post subject: | Re: How long a fuel line will a 40efi fuel pump pull through |
My tank is run up front my 18 foot crawfish skiff with no problems at all running a 40 eft bro |
Author: | Gigafowl [ Thu May 02, 2019 5:19 am ] |
Length is not as much an issue as diameter - smaller is better - use 1/4" line instead.... |
Author: | Buzz Killington [ Thu May 02, 2019 6:21 am ] |
Thanks guys Support your troops. We support you. B. |
Author: | MNGunner [ Thu May 02, 2019 6:45 am ] |
Author: | Russ [ Thu May 02, 2019 7:32 am ] |
I'll never run smaller fuel line than the size of the fuel pump inlet and outlet. My carb is 5/16, fuel pump is 5/16, 1/4 has to run faster through the line. Same concept as plumbing your house. The feed line shouldn't be smaller than the lines in your house. You're actually forcing the fuel pump to work harder. #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
Author: | Will [ Thu May 02, 2019 7:55 am ] |
Agree with Russ. Buzz, my 40 is modded, tank up front and 5/16" line all the way. Probably 20-25' total with no issues. I'd say 16-21' feet between pump and tank. |
Author: | MNGunner [ Thu May 02, 2019 9:25 am ] |
Author: | MaXXis85 [ Thu May 02, 2019 10:13 am ] |
Put a bulb, then the lift pump will do its job. Hell the pulse pumps pull 25' no problem |
Author: | Gigafowl [ Thu May 02, 2019 1:09 pm ] |
Author: | Buzz Killington [ Thu May 02, 2019 8:39 pm ] |
Author: | Wchauvin [ Thu May 02, 2019 10:31 pm ] |
So does mine and I don’t have any issues at all bro |
Author: | Buzz Killington [ Fri May 03, 2019 3:53 am ] |
Well I'm going to try it, thanks all for the feedback I wont be doing anything until after this weekend. Walleye tournament on the Bay of Quinte in Ontario. I will be the only mudmotor on the water - guaranteed. But I also make a point of never messing with something that is currently working before needing to use the boat. The line is run, all I need to do it hook it up and try it out. Support your troops. We support you. B. |
Author: | Wchauvin [ Fri May 03, 2019 5:40 am ] |
Sounds like a good time bro. Them people up there are going to look at that rig like crazy lol they don’t know what that is up there lol |
Author: | Buzz Killington [ Sun May 05, 2019 7:39 am ] |
Within 15 mins at the ramp Multiple pictures, lots of questions, tons of talking Lol Support your troops. We support you. B. |
Author: | Wchauvin [ Sun May 05, 2019 8:37 am ] |
Hahahahaha that’s awesome lol |
Author: | JIMMY W [ Mon May 06, 2019 6:23 am ] |
5/16 would be the best for your fuel line,3/8 will also work .gl |
Author: | Will C [ Mon May 06, 2019 8:08 pm ] |
Bigger the line the weaker the pulse. 5/16 max |
Author: | MaXXis85 [ Tue May 07, 2019 6:24 am ] |
Author: | Will C [ Tue May 07, 2019 7:38 am ] |
Russ giving me shit this morning so here is my defense |
Author: | Wchauvin [ Tue May 07, 2019 8:46 am ] |
When is Russ not giving somebody some heat? Lol good ol Russ |
Author: | bluesky2012 [ Tue May 07, 2019 6:48 pm ] |
When Russ finally finishes this magical build he’s been after, we can take him serious again! Sent from my iPhone using Tapatalk Pro |
Author: | Buzz Killington [ Wed May 08, 2019 5:21 pm ] |
Author: | dead animal [ Sat May 11, 2019 8:06 pm ] |
I run approx. 25' of 5/16'' fuel line on my 40 briggs. no problems. |
Author: | Buzz Killington [ Sun May 12, 2019 6:57 am ] |
So I gave it the ol college try this past week with seemingly no issues. I think I'll add a bulb to the line though.... Support your troops. We support you. B. |
Author: | MaXXis85 [ Tue May 14, 2019 5:18 am ] |
I always put a bulb to make it easier to prime, and if that lift pump fails you can keep fuel in the fuel pump module with the bulb. |
Author: | SP [ Tue May 14, 2019 5:30 pm ] |
Author: | Wchauvin [ Tue May 14, 2019 5:41 pm ] |
I have a bulb in mine as well |
Author: | MaXXis85 [ Wed May 15, 2019 6:07 am ] |
