gyates3
36 ProDrive Mods
Hey guys new member here being this is the first mud motor I have owned. I have a 2014 36hp prodrive on an 1860 southern duck boat hull. The boats main use will be for bowfishing, so hauling weight will be a must, Right now I’m seeing mid 20’s at a little under 4000 rpm’s. Not expecting much more for a boat that size. Just ordered a voodoo exhaust and a new stock prop. The stock prop seemed like the way to go after searching through the forums. The motor will be ran on pulleys and cables to a steer stick on the front. 75% of the fishing will be at idle. But I want some get up to chase down a fish and be able to haul a couple hundred pounds of fish at a reasonable speed. Any help is appreciated, what mods would y’all do?
Mon Apr 29, 2019 12:24 pm |
banded-mallard
Re: 36 ProDrive Mods
You have alot going on in that 1 paragraph.
-2014 PD on a 1860 - Ok big boat, but doable
-Currently mid 20's just under 4000 rpms - turn it up, why only 4000 rpms, or is it the motor can't push the hull. You should be able to turn it up more than that.
-keep the stock prop
-Could have asked before ordering a voodoo exhaust. You will see no difference in power, just louder. Exhaust is usually the last thing to put on an engine. There are way better things to "pump" up your engine that a "cool" looking exhaust
Mon Apr 29, 2019 12:44 pm |
gyates3
Not exactly sure how to turn it up.. I’ve messed with it a little. Turned the idle up a hair and tightened up some of the slop in the throttle linkage. It will turn 4200 rpms out of the water though.
Mon Apr 29, 2019 1:13 pm |
banded-mallard
Need to adjust governor. You should at least be 4350 if you don't have high Rev coils. If you do have high Rev coils, you should hit limiter at 4750 rpms. And your speeds will show a big difference.
Mon Apr 29, 2019 2:23 pm |
gyates3
Seems like this throttle linkage has a bunch of useless stuff on it lol. Could you point me in a right direction for the governor screw?
Mon Apr 29, 2019 2:44 pm |
banded-mallard
Screw it in clockwise. Start engine and let warm up. As your screwing it in, you shouldn't hear any change in idle. Rev engine and see if it made a change. If it did, turn in some more. Continue doing that until the gov screw starts to effect the idle. It will raise the idle. Back it off slightly until the idle comes back to normal. If you still can't get the rpms up, your govner spring may be shot, but that is a very rare occasion.
Tue Apr 30, 2019 3:13 am |
banded-mallard
gyates3
thanks for the help. The governor spring has 0 tension on it.. can’t be right
Tue Apr 30, 2019 6:12 am |
50fps
Tue Apr 30, 2019 5:31 pm |
gyates3
Believe I have the governor issue figured out now. Got the steering all hooked up tonight... now time to tap into the control box for the front steer stick. Anyone have an idea on how to do it? Plan is trim, ignition and clutch on the front and of course throttle.
Tue Apr 30, 2019 6:56 pm |
bluesky2012
36 ProDrive Mods
You’re going to hate having a voodoo running all night of bowfishing. That’s probably the least cost effective way to see a minor (if any) noticeable gain. I had one come with my engine, and getting rid of it was a great day.
Tue Apr 30, 2019 7:16 pm |
gyates3
95% of the fishing will be at idle.. and plus a generator I don’t think it will be that big of an issue. At least I hope not lol
Tue Apr 30, 2019 7:25 pm |
bluesky2012
36 ProDrive Mods
Tue Apr 30, 2019 7:42 pm |
Wchauvin
(In pirate voice) - I like me voodoo, matey lol
Tue Apr 30, 2019 8:19 pm |
gyates3
Well I searched through about all the threads on here and it seemed like everyone liked the voodoo so I went with it.
Tue Apr 30, 2019 8:33 pm |
bluesky2012
Tue Apr 30, 2019 11:38 pm |
Will
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Wed May 01, 2019 4:44 am |
gyates3
Wed May 01, 2019 7:05 am |
gyates3
Wed May 01, 2019 10:13 am |
Will
Should be able to add another switch and tie it into the same location as the original.
Wed May 01, 2019 11:42 am |
gyates3
Well I believe I have all my wiring figured out besides a kill switch.. I’ve got a 2 pole toggle switch that I want to somehow kill the motor from the front. I’ve tried using a ground to kill it but didn’t work. Any help?
Thu May 02, 2019 10:15 am |
gyates3
This is how I have my throttle cable tied in.. not a huge fan but it works. Trying to keep it away from the exhaust as much as possible. It works good but a little stiff.
Sun May 05, 2019 11:22 am |
gyates3
36 ProDrive Mods
Tore out the flimsy factory deck and storage and rebuilt the whole thing. Added a lot of weight but its a million times better than that thin factory deck. Steering turned out great and got everything wired up!
Sun May 05, 2019 11:25 am |
Wchauvin
That’s a nice damn shop lol
Sun May 05, 2019 5:52 pm |
gyates3
Sun May 05, 2019 7:09 pm |
Wchauvin
To say the least bro lol I’m happy for you, love your best life brother lol
Sun May 05, 2019 9:09 pm |
gyates3
Empty with just me it runs 22-23. Bowfishing load and 3 guys it runs a whopping 17. Is this normal speeds or what. Got it up to 4200 rpms.
Mon May 06, 2019 8:46 pm |
MaXXis85
Not enough motor for what you are trying to do. You have a 36 HP motor that weighs 325 pounds on a heavy boat.... Your trying to do what a 90 HP normally does
Tue May 07, 2019 6:22 am |
gyates3
Tue May 07, 2019 7:21 am |
Will
Sell that voodoo and get the heads worked, that will help.
Tue May 07, 2019 7:23 am |
gyates3
Tue May 07, 2019 7:52 am |
Wchauvin
Marcus and will are real good bro. Probably run about 1200 bucks and if you take them off yourself you can ship them to them
Tue May 07, 2019 8:47 am |
Russ
Head work is 650ish.
#CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor
Tue May 07, 2019 9:13 am |
Will C
^^ yep, heads run 650 fully worked with welded bosses
Tue May 07, 2019 10:03 am |
Wchauvin
I thought it was more, imma have to get mine done soon
Tue May 07, 2019 10:13 am |
Will
Tue May 07, 2019 12:59 pm |
EGood
Is it $650 per head or for the pair.
Tue May 07, 2019 4:52 pm |
Will
Pair
Tue May 07, 2019 5:10 pm |
gyates3
Finished product. This boat gonna be hell on some fish
Tue May 07, 2019 5:48 pm |
Will
I like it, simple...
Tue May 07, 2019 6:14 pm |
