It is currently Thu May 23, 2024 10:38 pm
Reply to topic  [ 10 posts ]
 Newer Gatortail running at 3500 RPMS help please
Post Newer Gatortail running at 3500 RPMS help please
Good morning, This may be self induced? I washed the crap out of my motor 2018 GTRXD 37EFI changed oil and transmission oil greased all fittings and greased lower unit. After that I went gigging and boat seemed to not run at full power??? Started good idles good. But wont get up on plane and run right??? What did I do? Because it ran fine before I did work. Now I washed it real good lots of water and simple green. PLEASE HELP
Mon Jun 03, 2019 2:51 am
Post Re: Newer Gatortail running at 3500 RPMS help please
Did you soak your air filter?
Support your troops. We support you.
B.
B. MacDonald
Mon Jun 03, 2019 5:45 pm
No sir I did check that. Hey thank you for the response.
Tue Jun 04, 2019 3:08 am
Any chance of a video? I would like to know if it's weak on 1 cyl or evenly weak on both. It could just be coincidence that you washed it
Wed Jun 05, 2019 12:54 am
Thank you Will C for the response, I will video Hopefully Friday, Will be next chance to get her in water. Or can I crank her in garage and video? I assume you want to see it in water under load?
Wed Jun 05, 2019 2:59 am
Either may help us figure out what's goin on
Wed Jun 05, 2019 9:34 am
Firing on both cylinders
Fri Jun 07, 2019 1:37 pm
Will C I was going to do a video but she ran great Friday? Yes firing on both cylinders. I do not know what was going on. Maybe just a heavy load? But I have had same load before and ran fine. I believe I need to do some motor upgrades.
Mon Jun 10, 2019 3:53 am
You fixed it! Your hired, lol
Mon Jun 10, 2019 8:55 am
That's what I am worried about I didn't do anything. I did have 7 batteries and 3 men in the boat BUT as I stated done that before without issue. Question would I be better off running my 2 blade prop or 3 blade with a heavy load?
Mon Jun 10, 2019 11:12 am
Users browsing this forum: Majestic-12 [Bot] and 179 guests
