Newer Gatortail running at 3500 RPMS help please http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=73872 |
Author: | Koondog62 [ Mon Jun 03, 2019 2:51 am ] |
Post subject: | Newer Gatortail running at 3500 RPMS help please |
Good morning, This may be self induced? I washed the crap out of my motor 2018 GTRXD 37EFI changed oil and transmission oil greased all fittings and greased lower unit. After that I went gigging and boat seemed to not run at full power??? Started good idles good. But wont get up on plane and run right??? What did I do? Because it ran fine before I did work. Now I washed it real good lots of water and simple green. PLEASE HELP |
Author: | Buzz Killington [ Mon Jun 03, 2019 5:45 pm ] |
Post subject: | Re: Newer Gatortail running at 3500 RPMS help please |
Did you soak your air filter? Support your troops. We support you. B. |
Author: | Koondog62 [ Tue Jun 04, 2019 3:08 am ] |
No sir I did check that. Hey thank you for the response. |
Author: | Will C [ Wed Jun 05, 2019 12:54 am ] |
Any chance of a video? I would like to know if it's weak on 1 cyl or evenly weak on both. It could just be coincidence that you washed it |
Author: | Koondog62 [ Wed Jun 05, 2019 2:59 am ] |
Thank you Will C for the response, I will video Hopefully Friday, Will be next chance to get her in water. Or can I crank her in garage and video? I assume you want to see it in water under load? |
Author: | Will C [ Wed Jun 05, 2019 9:34 am ] |
Either may help us figure out what's goin on |
Author: | Roostertail3 [ Fri Jun 07, 2019 1:37 pm ] |
Firing on both cylinders |
Author: | Koondog62 [ Mon Jun 10, 2019 3:53 am ] |
Will C I was going to do a video but she ran great Friday? Yes firing on both cylinders. I do not know what was going on. Maybe just a heavy load? But I have had same load before and ran fine. I believe I need to do some motor upgrades. |
Author: | Will C [ Mon Jun 10, 2019 8:55 am ] |
You fixed it! Your hired, lol |
Author: | Koondog62 [ Mon Jun 10, 2019 11:12 am ] |
That's what I am worried about I didn't do anything. I did have 7 batteries and 3 men in the boat BUT as I stated done that before without issue. Question would I be better off running my 2 blade prop or 3 blade with a heavy load? |
