X53Gunner
Max RPM's
I just picked up a new to me 2015 Pro-Drive with a 37hp EFI motor. I love the crap out of this thing! People up here in Michigan are like what the hell is that thing....LOL I'm just curious what is the max rpm I should be running this thing at for longer periods? I don't want to burn up my motor. Thanks for your help! New to the mud boats and love that I can get back where nobody else goes fishing.
Tue Jun 04, 2019 8:58 pm |
Will C
Re: Max RPM's
It being a 2015, it likely has a gen 3 lower unit with a 2:1 gear ratio. These usually run pretty high rpm. My guess is 4500-4600 at 25/26 mph. Bogging an engine is harder on it than letting it rev. Just keep a good prop on it and let it roll
Wed Jun 05, 2019 9:32 am |
X53Gunner
Re: Max RPM's
I do know the PO said it had the older gearing. Thanks for the info. Do these have a rev limiter?
Wed Jun 05, 2019 10:02 am |
Will
Re: Max RPM's
It does have rev limit, run it and let it eat, if it sounds like it's skipping, that's the limit, back off a hair.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Wed Jun 05, 2019 12:22 pm |
Wchauvin
Re: Max RPM's
If you need prop work, I know a guy lol
Wed Jun 05, 2019 4:27 pm |
bluesky2012
Re: Max RPM's
Wed Jun 05, 2019 6:02 pm |
Wchauvin
Re: Max RPM's
Glad you asked lol Mr baggy! lol
Wed Jun 05, 2019 6:33 pm |
X53Gunner
Re: Max RPM's
Cool thanks for all the reply's. Glad to hear there is a rev limiter now I don't have to worry as much. LOL These boats are Bad Ass!
Wed Jun 05, 2019 7:30 pm |
banded-mallard
Re: Max RPM's
Just to clarify because from your post, it appears that you are new to these things. It doesn't have a "rev limiter", so if you and your buddy's start looking around for the "rev limiter" to possibly "bypass it" or "modify it", there isn't one. The rev limiter is made into the coils and will cut spark thus acting like a rev limiter. That's why Will said what he said about skipping or cutting out, just back off throttle a little or pitch your prop to run WFO all the time. But you may have already read that in other posts.
Thu Jun 06, 2019 5:08 am |
X53Gunner
Re: Max RPM's
Yes you are correct banded-mallard I am new to these motors. Thank you for clarifying as it helped out. I'm a mechanic and fabricator so I do know a enough to get me in trouble...LOL I guess my main concern was running it WFO and blowing the motor so now I know I can let her rip!
Sat Jun 08, 2019 8:00 pm |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
Re: Max RPM's
4500 RPM’s was a sweet spot when I had the Gen 3. The Gen 4 I had ran best at 4100.
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
Tue Jun 11, 2019 7:19 pm |
