It is currently Wed Dec 17, 2025 4:54 pm
Reply to topic  [ 9 posts ]
 35 main bearring
Post 35 main bearring
Does anybody have he part number for the main crank bearrings/ bushings in the crank cover or a 35 vanguard? I’ve looked in the parts manual and can’t make out what’s what I’m it. Mines showing a little brass and wanna change it while i have it apart, any info is appreciated
Sun Feb 17, 2019 6:10 pm
Post Re: 35 main bearring
Ah...... you sure you want to do that? Hell I didn't even think it was this much :shock:
Mon Feb 18, 2019 6:36 am
You cant purchase the rear bearing. You need a new cover, You can only service the front bearing. It is $250 ish You also need a special tool to service the front bearings.
Mon Feb 18, 2019 7:43 am
Well shit. That’s not what i wanted to hear. Y’all agree it most definitely needs replaced though?
Mon Feb 18, 2019 9:06 am
Ive seen them way worse. Its from too much belt tension, and also removing the crankcase cover with rust on the end of the crank.
Mon Feb 18, 2019 9:45 am
Yeah.., Guilty of both. Lesson learned tho. Just ordered a new cover for 250$. I appreciate the info!
Mon Feb 18, 2019 12:53 pm
Mon Jun 10, 2019 1:37 pm
if you find someone with a trashed cover but good bearings you can have a engine shop swap out the babbit bearing. BEEN THERE, didnt go too bad actually just found someone with a cracked cover and and good bearing.
Tue Jul 09, 2019 1:51 pm
I found a whole short block on eBay a while back brand new for $500... I end up just getting that instead of replacing bearings. Couldn’t believe how expensive they are!
Thu Jul 25, 2019 6:19 pm
