It is currently Wed Mar 18, 2026 5:41 am
Reply to topic  [ 2 posts ]
 Gatortail CC 37 Hydraulic Steering
Post Gatortail CC 37 Hydraulic Steering
So I just picked up a GTR 1754 CC rig and the steering was really tough at one point when turning right (as the steering push rod retracted into cylinder). I turned the wheel really hard thinking it was just a rough spot and I was trying to get wheel all the way to one side so I could bleed the system. I disconnected lines and the pushrod is stuck in the retracted position. To replace the sleeve it runs through do you have to disassemble the motor mount? Other than where it goes through the motor mount the hydraulic cylinder moves in and out no issue.
Go Devil 1860 35 GDSD
Weldcraft 1548 22hp Predator GDLT
Sat Jul 27, 2019 8:13 pm
Post Re: Gatortail CC 37 Hydraulic Steering
To remove the sleeve, remove the steering ram, remove half, and full nut, remove both spacers. Hook up a strap to the lifting eyes on the valve covers, put enough of a bind on the engine to support the weight, slide the sleeve out and install the new sleeve using grease, reinstall in reverse order.
Sent from my SM-G975U using Tapatalk
Sun Jul 28, 2019 10:41 am
