| Reverse Issue? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=74059 |
| Author: | bjorndogg [ Mon Aug 05, 2019 8:39 am ] |
| Post subject: | Reverse Issue? |
Hi, took out my Mudbuddy 4400 BD HDR yesterday and the reverse wouldn't work off the trailer. It engaged and I would throttle up and nothing. I got it out on the water and tried it couple more times and still nothing. I ran the boat around for about 30 min and then tried it and it worked perfect. Is this something I should have looked at or maybe it fixed itself? My motor has close to 30hrs. Never had an issue before. Any help would be great. |
| Author: | DmaxHunter [ Tue Aug 06, 2019 5:34 am ] |
| Post subject: | Re: Reverse Issue? |
Was your battery weak to when you first tried? Sent from my SM-N950U using Tapatalk |
| Author: | bjorndogg [ Tue Aug 06, 2019 6:45 am ] |
No battery was fine. |
| Author: | bluesky2012 [ Tue Aug 06, 2019 7:50 am ] |
Doubt it “fixed itself”. I agree with Dmax on really scrutinizing your battery. An easy answer would be it was fairly low and had trouble fully engaging the electric clutch, then you ran it and the Briggs charged your battery then it started working. There are other possibilities, but if your wires look clean, that’s where I’d start. Sent from my iPhone using Tapatalk Pro |
| Author: | bjorndogg [ Fri Aug 23, 2019 6:29 pm ] |
Tried it again. Battery charged. Reverse not working correctly. It spins but doesn’t catch. Forward works perfect. Tried it all over the lake diff depths. Spins but won’t catch. On a weird occasion it will “catch” and reverse works perfect. 33hrs. On motor. One family member says they may have it reverse while on plane in forward. Switched it right back. Any help appreciated. |
| Author: | bluesky2012 [ Fri Aug 23, 2019 7:04 pm ] |
| Author: | bluesky2012 [ Fri Aug 23, 2019 7:59 pm ] |
Also, if you want to make yourself feel good that it’s not the clutch, snip the clutch wires (it’s just a Pos and Neg) and stick it straight to a battery. You will hear it engage. That will tell you it’s earlier in the system which means bad wire, ground, or switch. Sent from my iPhone using Tapatalk Pro |
| Author: | jc [ Sat Aug 24, 2019 5:32 pm ] |
I would think it's a bad switch or wire to the reverse. The battery should be ok because forward is working fine, so I would think if it has enough power for forward it should have the same for reverse. |
| Author: | Russ [ Sat Aug 24, 2019 6:49 pm ] |
Maybe so, but troubleshooting 101 means dont assume anything. Check it to isolate the issue. Could be something with that reverse clutch. #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
| Author: | bluesky2012 [ Sat Aug 24, 2019 8:13 pm ] |
| Author: | Will [ Mon Aug 26, 2019 5:56 am ] |
Here's a quick clip I made years ago showing how the magnet engages when 12v is applied. https://www.youtube.com/watch?v=7cH0X7-fwzo |
| Author: | bjorndogg [ Sat Sep 07, 2019 6:48 am ] |
Just a final update. It was the battery connectors that were corroded and bad. Had them all replaced. Battery tested fine. Reverse is working great once again! Thanks for all the help! |
