It is currently Fri Mar 20, 2026 12:02 pm
[ 4 posts ] |
dpd
Joined: Thu May 07, 2009 10:25 am Posts: 714 Location: Thibodaux, LA
 40 Valve Lash???
Just wondering those of you that are running and doing service work on the 40 EFI. Is there a particular valve lash setting that these motors do or don't like?? This is a stock motor question ----no mods
Briggs service manual gives .004-.006 on intake and .007-.009 on exhaust
The reason I ask is I checked lash on Sunday and they were loose, but the performance on the motor didn't seem to be off.
I'm just wondering what yall were going with
_________________ 16 x 48 Blanchard Bateau / 40 PD FPR Eat,Sleep, Fish, Hunt. Repeat.
| Tue Aug 20, 2019 8:08 am |
woffman
Joined: Tue Jan 13, 2009 6:35 pm Posts: 208 Location: WI
 Re: 40 Valve Lash???
MB told me .004 intake and. 006 exhaust on a cold motor. I checked mine for the first time after 12hrs and they were all way out of spec. I want to say they were all over .012.
| Tue Aug 20, 2019 11:28 am |
dead animal
it has been my experience with the 40 briggs that it don't matter where u set the valves, the 40 will do what he wants...
then throw pushrods..... then eat cam lobe....
lol, I just set them at .006 and roll out.
| Tue Aug 20, 2019 8:40 pm |
MaXXis85
I set at .005" and roll out. people don't understand why there is a specific lash. It is camshaft clearance ramp dependent. These cams have "short" clearance ramps unlike cams in the automotive world. That's why we see .004-.006" vs .015-.020" like older flat tappet motors. If you have too much lash you are opening the valve on the flank of the lobe causing a HARD acceleration which will eventually cause premature valvetrain wear and unwanted noise.. The other purpose of lash is to makes once the engine is heated up there is still sufficient clearance for oiling of the camshaft and valve stem tips. rocker arms. The best way is to set to mfr specs cold.. go run the motor, and do a hot lash check.. You should expect to see the clearance tighten, but still shouls see at least .002". Remember its even less clear on the cams base circle (that's determined by rocker ratio).
| Wed Aug 21, 2019 6:58 am |
[ 4 posts ] |
