| 2016 mud buddy hdr 37 losing power http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=74550 |
| Author: | bama_fowler [ Tue Sep 17, 2019 1:32 pm ] |
| Post subject: | 2016 mud buddy hdr 37 losing power |
I’ve got a 2016 mud buddy 37 efi on my excel. If I’m up on pad running WOT, eventually the motor will just cut out completely like i just pulled the kill switch. I can let off the throttle and it’ll pick right back up and keep going and will do it again unless I back off the throttle slightly. Wondering if anyone else has had the same issues? Or some idea as to what the problem could be Sent from my iPhone using Tapatalk |
| Author: | Russ [ Tue Sep 17, 2019 9:42 pm ] |
| Post subject: | Re: 2016 mud buddy hdr 37 losing power |
Vacuum leak, fuel pump not keeping up with injector needs, one of the sensors having a bit of issue at full throttle? Will C or Marcus likely to give more insight into that efi than I can but at least there are a couple ideas. #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
| Author: | jc [ Wed Sep 18, 2019 5:24 pm ] |
I had a friend with the same problem and his was caused by a fuel filter. His was doing the exact same thing. That would be something cheap and easy to try. |
| Author: | Will [ Wed Sep 18, 2019 10:58 pm ] |
Sounds like the high pressure fuel pump is getting weak. |
| Author: | Will C [ Thu Sep 19, 2019 2:53 pm ] |
Sounds to me like the hi pressure module isn’t staying full. I would replace fuel line, check quick connects, swap filter and low press pump just to make sure hi pressure pump can do it’s job |
| Author: | bama_fowler [ Sun Sep 22, 2019 1:42 pm ] |
I appreciate the help! Gonna run through some options this weekend and see if I can’t get it figured out Sent from my iPhone using Tapatalk |
| Author: | Glade [ Mon Sep 23, 2019 11:09 am ] |
One other possibility is a bad battery connection, or bad battery. If the ECM isn't getting enough voltage, it will kill the engine as if you pulled the kill switch. I was running an early 37 once, and every time I used the trim it would kill the engine because of the trim amp draw on the bad battery. |
