It is currently Sat Mar 21, 2026 4:08 am
[ 7 posts ] |
2016 mud buddy hdr 37 losing power
bama_fowler
I’ve got a 2016 mud buddy 37 efi on my excel. If I’m up on pad running WOT, eventually the motor will just cut out completely like i just pulled the kill switch. I can let off the throttle and it’ll pick right back up and keep going and will do it again unless I back off the throttle slightly. Wondering if anyone else has had the same issues? Or some idea as to what the problem could be
| Tue Sep 17, 2019 1:32 pm |
Russ
 Re: 2016 mud buddy hdr 37 losing power
Vacuum leak, fuel pump not keeping up with injector needs, one of the sensors having a bit of issue at full throttle? Will C or Marcus likely to give more insight into that efi than I can but at least there are a couple ideas.
#CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor
| Tue Sep 17, 2019 9:42 pm |
jc
I had a friend with the same problem and his was caused by a fuel filter. His was doing the exact same thing. That would be something cheap and easy to try.
| Wed Sep 18, 2019 5:24 pm |
Will
Sounds like the high pressure fuel pump is getting weak.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Wed Sep 18, 2019 10:58 pm |
Will C
Sounds to me like the hi pressure module isn’t staying full. I would replace fuel line, check quick connects, swap filter and low press pump just to make sure hi pressure pump can do it’s job
| Thu Sep 19, 2019 2:53 pm |
bama_fowler
I appreciate the help! Gonna run through some options this weekend and see if I can’t get it figured out
| Sun Sep 22, 2019 1:42 pm |
Glade
One other possibility is a bad battery connection, or bad battery.
If the ECM isn't getting enough voltage, it will kill the engine as if you pulled the kill switch.
I was running an early 37 once, and every time I used the trim it would kill the engine because of the trim amp draw on the bad battery.
| Mon Sep 23, 2019 11:09 am |
[ 7 posts ] |
