35 gatortail center console starter trouble
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=74667
Author:  champtd [ Mon Oct 28, 2019 9:49 am ]
Post subject:  35 gatortail center console starter trouble
I have a 35 gtr center console giving me trouble,sometimes it cranks right up , most times it makes one loud click. I put a new starter and same thing.checked battery its ok. Im thinking its the wires going to clutch that ensure its not in gear but Im not familiar how that works. I can tap on it and it starts but I need it fixed,any ideas?
Author:  brycecheramie [ Mon Oct 28, 2019 9:53 am ]
Post subject:  Re: 35 gatortail center console starter trouble
I JUST fixed this issue on mines.
You have a 12 volt wire running from your key switch to a spade connector on your starter. It is small and sometimes gets frayed. Get you a thicker gauge wire, and replace that old wire with a thicker wire.
That is ALL i did and it solved my issue altogether.
Author:  brycecheramie [ Mon Oct 28, 2019 9:56 am ]
Also, as always, check your connections first.
Make sure battery is good, and grounds are tight.
But this solved my issue 100%
Author:  lastchance [ Tue Oct 29, 2019 7:38 pm ]
You can also check your circuit breaker
Sent from my SM-G975U using Tapatalk
Author:  3rd Coast Killer [ Thu Oct 31, 2019 12:57 pm ]
I had this problem for awhile. Replaced all of the power wire, Key wire, main wire, everything, still the dreaded click click.
Marcus (maxxis85) on here builds a little relay that you put inline with the starter. Installed almost 3 years ago and have never had the problem sense.
Shoot him a PM.
