It is currently Sun Jul 12, 2026 7:03 am
Reply to topic  [ 16 posts ]
 40 Efi powerhead
Post 40 Efi powerhead
Does anyone know model and type code for the 40 Efi? I have a buddy thats thinking about putting one on his 2010 gatortail. His 35 thats on it now has Calen's heads and cam and a mikuni and BPS Q. How will the 40 compare?
Thu Dec 19, 2019 8:08 pm
Post Re: 40 Efi powerhead
Model# 61G477 0001-J1
Sent from my SM-G975U using Tapatalk
Thu Dec 19, 2019 10:13 pm
Fri Dec 20, 2019 6:21 pm
Thanks for the replies. His has been a good strong motor, but he has had the typical briggs case gasket issue from the start. Gator tail replaced a cracked rear cover with only 70 hours. It has had 2 more cracked covers after that and 2 gaskets replaced in between. The last time the cover was replaced he had a machine shop do the mods to delete the gasket and now it's leaking again. Bolts have never got loose and always had red loctite. Pretty sure it's a internal balance issue causing it because it has had several props so that shouldn't be the cause.
Fri Dec 20, 2019 7:24 pm
Could also be the 100 lbs of unbalanced shit hanging off the crankshaft...
Fri Dec 20, 2019 7:29 pm
That's not good. I would have thought with everything back there being machined and not just cast that it would be balanced or very close.
Is the planetary known for having balance issues or it something else?
Fri Dec 20, 2019 7:35 pm
Is he running stock props or props that have been balanced. You would be surprised how out of balance new props are out the box, especially 2 blades
Fri Dec 20, 2019 7:47 pm
All stock 2 blade props straight from gator tail.
Fri Dec 20, 2019 8:03 pm
Might be part of your problem with vibration
Sat Dec 21, 2019 9:53 am
Balanced or not, the planetary is a big chunk of rotating metal with nothing supporting the end of the PTO shaft. Theres vibration whether you like it or not. Multiple props arent going to continually cause covers to crack even if they arent balanced.
#GhostBoat
#Whoneedsphysicsihaveamudmotor
Sat Dec 21, 2019 11:38 am
When I was searching for info on the 40 efi I noticed several threads about leaking cases on the 37 and 40 efi but not anything like in the past with the 35 before they did away with the gasket. So the problem is still there but not as often as before. I remember Maxxis and maybe deadbird talking about how bad some of the cranks or maybe flywheels were on some of the briggs, so he was hoping that was the problem. Any suggestions on checking everything outside the engine?
Sat Dec 21, 2019 8:15 pm
I’m not saying that is the culprit for him, just saying that getting a propeller balanced will help with a part of the vibration. If I would have thought that the balancing of the prop was the fix all for him, I wouldn’t have said that it may be “part of the problem”. I’m sure there are bigger issues here because even unbalanced you shouldn’t be having the problems you are having, but balancing your prop can only help while you discover the other issues.
Sat Dec 21, 2019 10:15 pm
Yeah, need to get the prop checked. I'm sure it will help.
Mon Dec 23, 2019 7:17 pm
He will be disappointed I. The 40efi compared to what he has from a power standpoint. It’s all I can do to not modify my new 40. Will never make 3 years before I do. Ive only had it since thanksgiving and my last motor had the same mods as your buddy, but it wasn’t as troublesome as his.
18'x54"CC Hanko/ 36PD
Tue Mar 03, 2020 6:51 pm
Thanks pooldoo. That's what he was wanting to know. It's been a good strong motor other than the case issues. I have run several other gatortails and
they all had way less vibration than his. I'm sure it's a balance issue somewhere.
Tue Mar 03, 2020 7:53 pm
You would be shocked the difference one prop will make the other. A balanced and worked prop is heaven.
I really love my 40hp.
40HP Gatortail
Tue Mar 03, 2020 10:09 pm
