It is currently Thu Nov 19, 2026 12:28 am
[ 4 posts ] |
JBsuperG
Joined: Wed Mar 21, 2018 2:51 pm Posts: 263 Location: Michigan
 Help removing clutch
Looking for suggestions getting the clutch the rest of the way off. The outside piece came off with a little finesse. The inner part of the clutch slid part way off then got stuck. I don't want to damage it. Any suggestions are appreciated. 20200106_202056.jpg 20200106_202110.jpg
| Mon Jan 06, 2020 7:33 pm |
Russ
 Re: Help removing clutch
Since it slid some, go back on with it, then try again until it comes off. Theres a spot of rust or whatever it's hanging up on, and you can probably work it smooth enough to slide that off. May be the key, but probably just something on the shaft.
| Mon Jan 06, 2020 7:56 pm |
BlueShamu
Like Russ said...push it back on. Then, take a piece of Scotch-Brite and polish what you can see on the crank. Then, oil it up with a light oil...WD-40 or such. Then, try again.
Sent from the ISS using Tapatalk.
| Mon Jan 06, 2020 8:09 pm |
JBsuperG
Thanks guys. That worked.
| Mon Jan 06, 2020 8:40 pm |
[ 4 posts ] |
