| Bolting governor hole question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=74855 |
| Author: | JBsuperG [ Wed Jan 08, 2020 4:49 pm ] |
| Post subject: | Bolting governor hole question |
I have a 1/2 13 tap that I'm going to use to thread the hole for the governor. It seems to be about the correct size. My question is, besides loctite should I use some RTV at the shoulder of the bolt? Also, is there anything else I should know? |
| Author: | Will [ Wed Jan 08, 2020 5:46 pm ] |
| Post subject: | Re: Bolting governor hole question |
No need to tap it, most just put a bolt through it with a nut and lock washer or nylon lock nut and washer with rvt. But, it you going to tap, yes, just rvt sealant should work. Sent from my Pixel 2 using Tapatalk |
| Author: | JBsuperG [ Wed Jan 08, 2020 6:43 pm ] |
I've seen it both ways. I figured tapping it would prevent the risk (although slight) of the nut getting loose. |
| Author: | cb5331 [ Thu Jan 09, 2020 9:53 am ] |
Just cut the flipper off the shaft and stick the shaft back in. Sent from my SM-T710 using Tapatalk |
| Author: | MaXXis85 [ Thu Jan 09, 2020 10:08 am ] |
| Author: | JBsuperG [ Thu Jan 09, 2020 1:53 pm ] |
| Author: | cb5331 [ Thu Jan 09, 2020 3:58 pm ] |
| Author: | cb5331 [ Thu Jan 09, 2020 3:59 pm ] |
Make sure you take the governor gear out of the inside of the block when you’re in there. |
| Author: | Russ [ Thu Jan 09, 2020 4:23 pm ] |
I just left the paddle shaft with the keeper clips inside and out. Cut the paddle off so it's a straight shaft and pull the governor stuff out of the inside of the engine. Been working fine on my time bomb. Sent from my SM-G970U using Tapatalk |
| Author: | JBsuperG [ Fri Jan 10, 2020 6:00 am ] |
| Author: | Russ [ Fri Jan 10, 2020 6:18 am ] |
Pull it. You'll notice when you have it apart the gov gear and the weights just pop right off with a bit of pressure. Maybe use a screwdriver to pry it off. Sent from my SM-G970U using Tapatalk |
| Author: | JBsuperG [ Fri Jan 10, 2020 6:55 am ] |
There we go. It is off. It faught it and faught it and then all of a sudden slid off with ease. I saw a video on line where it lifted off pretty easy, but mine took a little bit more effort. Not being familiar with it I didn't want to force it. |
| Author: | bluesky2012 [ Fri Jan 10, 2020 8:09 am ] |
If it’s a 35 but no mikuni, be prepared to put on an additional spring that didn’t come on the stock carb and throttle assembly. Sent from my iPhone using Tapatalk Pro |
| Author: | JBsuperG [ Fri Jan 10, 2020 9:01 am ] |
