| Oil Cooler - 2012 Gatortail http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=74917 |
| Author: | SlimOx [ Fri Jan 17, 2020 10:59 am ] |
| Post subject: | Oil Cooler - 2012 Gatortail |
Hey all, I've got a 2012 GTR 35. My oil cooler cracked. Not really a problem, but the new oil coolers aren't the same and GTR doesn't make my model anymore. I am able to retrofit one, but that requires taking the support bracket off which I don't like. Anyone know where I can find the correct oil cooler so I can get it fixed correctly after duck season? Thanks in advance. |
| Author: | Russ [ Fri Jan 17, 2020 11:25 am ] |
| Post subject: | Re: Oil Cooler - 2012 Gatortail |
https://www.partstree.com/models/613477 ... coolers-8/ Sent from my SM-G970U using Tapatalk |
| Author: | SlimOx [ Fri Jan 17, 2020 11:30 am ] |
Russ - thank you so much. From what I can tell, I need the oil cooler from part 400A, but I don't need the bracket and the oil cooler from part 400 is the wrong cooler. Mine has the two holes that mount to the front housing (instead of the new design with a single hole). |
| Author: | Will [ Fri Jan 17, 2020 11:50 am ] |
Search the forum, I found one years ago that was an off brand but can't remember where. It was actually a transmission cooler. Work great for a lot less money. |
| Author: | Will [ Fri Jan 17, 2020 2:05 pm ] |
Found it, the small power steering cooler. The ONLY difference is the top flange is straight, you'll need to bend it about 30 degrees like the old one. It bends easy. Straight bolt on after that. http://www.bakerprecision.com/trucool.htm |
| Author: | mizzippi jb [ Sat Jan 18, 2020 6:02 am ] |
You can't get this type of good info off Facebook. Shame folks don't come around more. |
