It is currently Mon Jul 13, 2026 1:27 am
Reply to topic  [ 9 posts ]
 Modded motor mechanic suggestions in texas
Post Modded motor mechanic suggestions in texas
Anyone have any suggestions on shops to work on a modded vanguard 36? I can’t seem to get this thing running on more than one cylinder. Thanks.
Sun Feb 09, 2020 11:49 am
Post Re: Modded motor mechanic suggestions in texas
Im in Gladewater, Marcus is in Cleveland, Pete Willet in Flint tx.
Sun Feb 09, 2020 12:05 pm
Marcus at Bayou Surface Drives
Sun Feb 09, 2020 4:49 pm
40HP Gatortail
Tue Feb 11, 2020 7:51 am
My MB 40 Hp Kohler runs on 1 cylinder every time I trailer it too far. Turned out it was flooding out because the gas cap was tight and the shaking of the gasoline was pushing through the carb and flooding it out.
I used Tycoon in OK. I will not recommend as he didn't diagnose the simple issue.
Wed Feb 12, 2020 7:32 pm
Tx is pretty big where are you located?Will and Marcus both do great work though.
Sat Feb 15, 2020 8:14 pm
Sorry y’all. Been busy here at home and work. I’m in Central Texas, but make it to the Houston area occasionally. Usually never make it up towards Dallas. I’ll try and reach out to one of the guys over near Houston and see if they are able to help me out and get the boat in to take a looksee
Thu Feb 20, 2020 2:57 pm
Nick Willey is in Nederland. Does great work but you usually gotta wait a bit.
Thu Feb 20, 2020 5:06 pm
Depends on your location. Being your location your probably about the same drive to myself or Will C.
Fri Feb 21, 2020 9:35 am
