It is currently Fri Mar 13, 2026 4:37 pm
Reply to topic  [ 6 posts ]
 Need help on a couple of parts
Post Need help on a couple of parts
Hopefully you boys can help me replace a couple parts on my 2002 23hp GD longtail. Anybody know the size of bolts that hold the oil cooler in place? Mine rattled out. Also looking for a good replacement for the stock fuel pump. Called GD but they weren't any help unless i had my serial # with me. I dont keep the boat at the house and want to grab the parts before i head out fishing this weekend.
Thanks in advance!
Wed Mar 04, 2020 9:51 pm
Post Re: Need help on a couple of parts
40HP Gatortail
Wed Mar 04, 2020 10:15 pm
Once you register it with them you won’t have to have your number. Just your name and info and they can pull it up as belonging to you.
Wed Mar 04, 2020 11:53 pm
That used to be the case as I registered with them 15 or so years ago. Hoping someone knows the bolt size so I can take them with me. The pump can wait.
Wed Mar 04, 2020 11:59 pm
May at least be able to get part numbers for you....then, maybe a Briggs service center can give you either the actual part or maybe the dimensions.
Sent from the ISS using Tapatalk.
Thu Mar 05, 2020 7:23 am
thanks!
Thu Mar 05, 2020 8:45 am
Users browsing this forum: Ask Jeeves [Bot] and 1 guest
