It is currently Sun Jun 22, 2025 1:18 pm
Reply to topic  [ 8 posts ]
 Mikuni Carb Boot
Post Mikuni Carb Boot
I have a Mikuni carb on a 35 gatortail, and the black rubber carburator boot or flange has a large crack. The motor now runs terrible at low rpms, and will die at idol because it is running way too lean due to the air leak that just developed. I was able to limp back to the launch. To replace the boot is it as simple as taking off the carb by undoing the hose clamp and then removing the two Allen screws and replacing the carb boot? Is there any sealant or something between the rubber carb boot and the metal intake manifold? The old flange seems to be sealed to the intake manifold in some way. Also, Is there any way to better support the carb than just its whole weight being held up by the plastic flange? Thanks for any help you can offer.
Sun Apr 05, 2020 1:12 am
Post Re: Mikuni Carb Boot
I always carry a spare, the vibration on theese engines will loosen the clamps so checking them is a good idea i have never used any sealant just kept it tight, Says Ronbow
Gator Trax 16/50 ---HDR Black Death 4500 BPS SWAMP STAFF
Sun Apr 05, 2020 7:32 am
I also have a Boat Dr. cover for my carb, they are cheap and are worth the trouble on the vertical or horizontal engines says Ronbow Boat Dr. 504 737 1203
Sun Apr 05, 2020 7:37 am
2 big zip ties in an x will hold fine and take the stress off that boot. Could also take a thin piece of sheet aluminum or steel from the hardware store and bend it to act as a support underneath the carb and bolt it in.
Sun Apr 05, 2020 9:44 am
Lead, Follow or Get The Hell Out Of The Way!!!!
1754 Gator Trax Hybrid, Hunt Deck ,with MB 4400 Black Death HDR, Duck Slaying, Mud Slingin Machine!!!
Wed Apr 08, 2020 9:36 am
Profile YIM
Thu Apr 09, 2020 12:30 pm
Profile YIM
Just FYI.......I had one crack a long time ago and sealed it with aqua seal wader repair stuff. It’s still holding to this day.
Sat Apr 11, 2020 11:50 pm
Sun Apr 12, 2020 6:26 am
Profile YIM
Users browsing this forum: Google [Bot] and 143 guests
