It is currently Wed Oct 21, 2026 3:33 am
Reply to topic  [ 2 posts ]
 MB mini throttle adjustments
Post MB mini throttle adjustments
I have a mud buddy 23hp mini and notice it’s cutting out on me only when the governor arm frees up. I know I can make changes to make it run higher rmps but not looking for that. I’m walking a trot line at 680-740 if my fingers slightly holding the lever to keep the play out of the line motor runs like a dream. Anyone out here buy a after market adjustable clutch lever ? Or even a bicycle
Brake lever /line and coupling to the stock. Have a couple ideas im thinking that would work but wanted to check here first.
My goal is the find a lever with a quick adjustment on it so I can turn up and down rpms on the handle. Thanks
Also anyone know the gauge off hand the stock ball and cable housing
Mon May 18, 2020 5:56 pm
Post Re: MB mini throttle adjustments
That idea will probably work. But if you move your handle up and down it will accelerate by itself. U could drill an access hole in front of the idle screw on carburetor. Then keep a flathead close by for bumping the screw up or down
Wed May 20, 2020 10:56 am
