It is currently Thu Jun 11, 2026 2:44 pm
Reply to topic  [ 3 posts ]
 Governor issues........
Post Governor issues........
GTR 25 Subaru
3570rpm neutral out of the water
Governor adjusted all the way counter clock wise per the instructions in the manual.
If I adjust the governor halfway or all the way clockwise it bounces at 4100 idling and the throttle plate nor the governor arm move when applying throttle.
Is the governor rod worn out? Or maybe the gear? Are parts even available?
Is it normal to be able to pull the governor rod up and down 1/8” or so?
1652 modV 35GTR
Sun Jun 07, 2020 5:15 pm
Post Re: Governor issues........
Is the throttle plate fully closed at idle? Had a case where the throttle plate was stuck open. Just a thought.
Mon Jun 08, 2020 6:34 am
I’ll check tonight. But everything operates 100% normal with the gov adjusted counter clockwise. I think I’m going to unhook the gov and see what she does??
1652 modV 35GTR
Mon Jun 08, 2020 7:42 am
