It is currently Wed Apr 17, 2024 8:08 pm
Reply to topic  [ 9 posts ]
 Which jets to run?
Post Which jets to run?
Doing some mods to a 2009 35GTR. As of now it has Mikuni 42 mm carb, Black Death Intake and Double Barrel Marshmellow Performance Exhaust.
In the near future i'm going to be doing .50 Delta heads and a .310 Delta camshaft. Have the parts just havent started the project yet. Just curious as to what jets in the carb to start with? Im in Iowa roughly 1000ft altitude. Also what ballpark rpm increase should i be seeing after this? With a worked Big Blade prop i run around 4k now. Any help is appreciated, thanks.
Gator-Tail 1860 Extreme/GTR35 Stage 3
Wed Jul 15, 2020 12:11 pm
Post Re: Which jets to run?
162.5, 165, 167.5 main
One of those will likely be correct. Probably the 165 or 167.5
#mudmotor>physics
Wed Jul 15, 2020 12:58 pm
Is the main jet the only one that will need changed or will the pilot also need changed?
Wed Jul 15, 2020 2:10 pm
The pilot is a maybe, but I doubt it.
#mudmotor>physics
Wed Jul 15, 2020 2:34 pm
You may need to adjust the needle.
#mudmotor>physics
Ok I'll see how it runs with just a main jet change first. Thanks!
Wed Jul 15, 2020 7:42 pm
I have the same carb (love it by the way) on my 4400 HDR Black Death. I put a performance cam, and roller rocker/push rods on my motor. I bought the 162.5 and 165 jets... and found out, (FOR ME) the 162.5 worked out the best for my setup. After putting it in,, and running it for 5-10 min. to get the engine hot... I made multiple runs keeping trim and weight exactly the same on ech run and slowly opening up the high speed needle to find her G-spot... Once everything was said and done. I'm running on a hammer prop. going 33mph at 4300RPMs in my Gator Trax 17X54 w/hunt deck, 2 batteries, a trolling motor, 9gal. of gas and me. Speed is something I can care less about... Hauling 3 guys their gear and 10 dozen decoys and still have enough ass to get OUT of most any situations is what I yern for (and now have even more of)!! My high speed screw is now 2 1/2 turns open compared to the 1 3/4 turn it orig. was. Spark plugs are nice and gray and she reacts to WOT much better and purrs like one of Carole Baskin's tigers now... best thing I've done to this bad ass motor...
Lead, Follow or Get The Hell Out Of The Way!!!!
1754 Gator Trax Hybrid, Hunt Deck ,with MB 4400 Black Death HDR, Duck Slaying, Mud Slingin Machine!!!
Thu Jul 23, 2020 9:42 am
Profile YIM
What pilot jet matches up to those main jets?
Sun Mar 20, 2022 8:22 am
Sun Mar 20, 2022 9:24 am
Profile YIM
Users browsing this forum: W3C [Validator] and 196 guests
