It is currently Sun Jun 22, 2025 7:59 am
Reply to topic  [ 5 posts ]
 23hp cylinder knocking. Rebuild or is it repairable?
Post 23hp cylinder knocking. Rebuild or is it repairable?
Had an outboard on my boat for a few months and decided to put my 23hp mud buddy LT back on for duck season coming up. Started her up no problem but immediately knocking hard on one cylinder. (Video attached). Took the plug out to find it black and the piston grinding on the cylinder wall. Not sure of the damages done but definitely not trying to put a bunch of money into this old thing. What can be done????
Mods= timing advance key, hi rev kit (spring shims and valve rods) , thin head gaskets, carb kit, gov. lockout).
1438 Jon / 23hp MBLT
Thu Sep 17, 2020 10:00 pm
Post Re: 23hp cylinder knocking. Rebuild or is it repairable?
Shortblock is only bout a 900 range i think. Rebuild youself goin .020 over for 4/500
Thu Sep 17, 2020 10:08 pm
I found a bare block online for $85 and pistons for $30 each. Can everything else come from my engine or is there more I'm gonna need besides obvious gaskets and stuff.
Tue Sep 29, 2020 8:29 am
It depends on if the rod was damaged, and if it messed up the crankshaft or not, as well as the head. You won't know that until you take the old engine apart and start inspecting everything. You will need rings for the pistons, and a hone for the cylinders on your "new" block. Maybe new pins for the pistons/rod link.
#mudmotor>physics
Tue Sep 29, 2020 8:35 am
Alrighty. When I tear into it I'll see and probably post it to get more advice.
Thanks.
Wed Sep 30, 2020 12:22 pm
Users browsing this forum: Google [Bot] and 182 guests
