It is currently Fri Jan 30, 2026 6:04 pm
[ 6 posts ] |
09 35hp mud buddy Dropping a cylinder
DuckWelder
09 35hp mud buddy. Motor started running rough and seemed to drop a cylinder randomly . Recently replaced the ignition coils. Did a tune up and checked compression. Both cylinders hold at 120psi. Motor ran like new for a few trips then recently started running rough and acts the same it did like a cylinder drops out . Pulse pump or carb issue? Or could a sticky valve could be causing this ?
| Mon Aug 10, 2020 12:56 pm |
brycecheramie
 Re: 09 35hp mud buddy Dropping a cylinder
| Mon Aug 10, 2020 2:06 pm |
Russ
Plug boot arcing. Wrap them and a couple inches of wiring real good with electrical tape and see if it solves your issue. Could be a coil, but those seem to either work or not. They don't typically cause intermittent issues.
#CFFITR #mudmotor>physics
| Mon Aug 10, 2020 2:08 pm |
DuckWelder
| Mon Aug 10, 2020 3:38 pm |
DuckWelder
| Mon Aug 10, 2020 3:39 pm |
DuckWelder
| Mon Aug 10, 2020 3:53 pm |
[ 6 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 1 guest |
