| 09 35hp mud buddy Dropping a cylinder http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=75237 |
| Author: | DuckWelder [ Mon Aug 10, 2020 12:56 pm ] |
| Post subject: | 09 35hp mud buddy Dropping a cylinder |
09 35hp mud buddy. Motor started running rough and seemed to drop a cylinder randomly . Recently replaced the ignition coils. Did a tune up and checked compression. Both cylinders hold at 120psi. Motor ran like new for a few trips then recently started running rough and acts the same it did like a cylinder drops out . Pulse pump or carb issue? Or could a sticky valve could be causing this ? Sent from my iPhone using Tapatalk |
| Author: | brycecheramie [ Mon Aug 10, 2020 2:06 pm ] |
| Post subject: | Re: 09 35hp mud buddy Dropping a cylinder |
| Author: | Russ [ Mon Aug 10, 2020 2:08 pm ] |
Plug boot arcing. Wrap them and a couple inches of wiring real good with electrical tape and see if it solves your issue. Could be a coil, but those seem to either work or not. They don't typically cause intermittent issues. #CFFITR #mudmotor>physics |
| Author: | DuckWelder [ Mon Aug 10, 2020 3:38 pm ] |
| Author: | DuckWelder [ Mon Aug 10, 2020 3:39 pm ] |
| Author: | DuckWelder [ Mon Aug 10, 2020 3:53 pm ] |
