It is currently Thu Nov 26, 2026 12:15 am
Reply to topic  [ 9 posts ]
 Reliability issue after BPS modification ?
Post Reliability issue after BPS modification ?
Hi Guys,
I’m looking to install the Carb kit Mikuni 42mm of BPS on my GoDevil SD35 2011.
Anyone has did that and is satisfied ? Any reliability issue after the modifications
Thx for your help
Martin
Using Tapatalk
Mon Nov 09, 2020 5:02 pm
Post Re: Reliability issue after BPS modification ?
Everyone has had issues. Mainly because of the investments they decide to do after because they want more power. No, editing the fuel provider wont hurt reliability at all. Just remember you won't have a governor anymore to limit rpms.
#mudmotor>physics
Mon Nov 09, 2020 6:07 pm
Thanks for the answer.
Not sure I understand, people has issue because they want more power so they spent more money ? Just the carb kit will not gave me extra couple HP?
Regards
Using Tapatalk
Wed Nov 11, 2020 7:13 am
Yes. People get a carb. Then they want headwork to take more advantage of the extra fuel and air. Then an exhaust. Then a cam. Etc. The carb alone doesn't affect reliability directly, you just lose the built in governor, so no rev limit with the older non-cdi engines unless you add the rev limiter from bps. A stock 35 or a 35 with headwork can actually get benefit from using a 36mm flat slide mikuni. That's how i set up my Dad's. But his has no cam or aftermarket exhaust, so the 36mm is plenty. The 42 is fine, but more carb than is needed on a stock 35 briggs.
#mudmotor>physics
Wed Nov 11, 2020 9:32 am
Thank you very much, your help is very appreciated.
Would say that your Dad’s 35 hp has more hp with the 36mm and a higher top speed ?
Regards
Using Tapatalk
Wed Nov 11, 2020 3:02 pm
Have you considered the Ecotrons EFI kit? It has worked well for me for several years.
Wed Nov 11, 2020 3:11 pm
I don’t know this system. Can you tell me more :O)
Using Tapatalk
Wed Nov 11, 2020 3:16 pm
Ecotrons fuel injection. Google it. Great throttle response, no carb icing, better fuel economy, and easy cold weather start. I started running it before Briggs offered EFI. On an otherwise stock 35hp engine the performance was the same as a 37.
Wed Nov 11, 2020 4:55 pm
Yes, the 36 made quite the difference with a load both before and after the headwork, and is faster empty.
A 42 will as well.
#mudmotor>physics
Wed Nov 11, 2020 6:43 pm
