It is currently Thu Mar 19, 2026 4:49 am
Reply to topic  [ 6 posts ]
 Sporadic Idle and Throttle Lag
Post Sporadic Idle and Throttle Lag
Hey guys,
2012 CDI 35. Will C mods on a short block. Mikuni carb. Cam, rods springs etc. high rev coils. The whole shabang. Been running like a top. Changed fluids, and now I’ve got sporadic idle. Checks valve lash, intake was off a bit. Everything set back to .005.
I’ve tinkered with carb. Throttle is lagging, sounds like it’s starving/sucking for air, then it jumps up and runs perfect. Still pushing full 33mph. Let off throttle, idle is high after running WOT then it settles in. 10-15 seconds it will idle up just slightly and fall back.
Can’t figure this one out. I guess it could be a gasket somewhere. Places to start?
Any help is appreciate. Will, if you see this feel free to call :)
Tue Nov 17, 2020 5:42 pm
Post Re: Sporadic Idle and Throttle Lag
Check your intake adapter. The rubber that mounts the carb to the intake can crack over time and cause issues.
Tue Nov 17, 2020 6:49 pm
Also check where the intake bolts to the egine. Sounds like an intake leak somewhere.
#mudmotor>physics
Tue Nov 17, 2020 7:23 pm
Also check the black vacuum plugs on that carb for cracks
Sent from my SM-G975U using Tapatalk
Wed Nov 18, 2020 6:13 pm
I’ve discovered a gasket tear upon removing the carb. Also realized threads have possibly vibrated a screw out or the threads are stripped. Looks like a rethread is necessary. Yikes.
Wed Nov 18, 2020 7:09 pm
I agree with these guys. Especially the gaskets between intake and heads
Thu Nov 19, 2020 2:34 pm
