| Sporadic Idle and Throttle Lag http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=75416 |
| Author: | SlimOx [ Tue Nov 17, 2020 5:42 pm ] |
| Post subject: | Sporadic Idle and Throttle Lag |
Hey guys, 2012 CDI 35. Will C mods on a short block. Mikuni carb. Cam, rods springs etc. high rev coils. The whole shabang. Been running like a top. Changed fluids, and now I’ve got sporadic idle. Checks valve lash, intake was off a bit. Everything set back to .005. I’ve tinkered with carb. Throttle is lagging, sounds like it’s starving/sucking for air, then it jumps up and runs perfect. Still pushing full 33mph. Let off throttle, idle is high after running WOT then it settles in. 10-15 seconds it will idle up just slightly and fall back. Can’t figure this one out. I guess it could be a gasket somewhere. Places to start? Any help is appreciate. Will, if you see this feel free to call Sent from my iPhone using Tapatalk |
| Author: | jc [ Tue Nov 17, 2020 6:49 pm ] |
| Post subject: | Re: Sporadic Idle and Throttle Lag |
Check your intake adapter. The rubber that mounts the carb to the intake can crack over time and cause issues. |
| Author: | Russ [ Tue Nov 17, 2020 7:23 pm ] |
Also check where the intake bolts to the egine. Sounds like an intake leak somewhere. #CFFITR #mudmotor>physics |
| Author: | lastchance [ Wed Nov 18, 2020 6:13 pm ] |
Also check the black vacuum plugs on that carb for cracks Sent from my SM-G975U using Tapatalk |
| Author: | SlimOx [ Wed Nov 18, 2020 7:09 pm ] |
I’ve discovered a gasket tear upon removing the carb. Also realized threads have possibly vibrated a screw out or the threads are stripped. Looks like a rethread is necessary. Yikes. Sent from my iPhone using Tapatalk |
| Author: | Will C [ Thu Nov 19, 2020 2:34 pm ] |
I agree with these guys. Especially the gaskets between intake and heads |
