It is currently Tue Mar 17, 2026 12:35 am
Reply to topic  [ 5 posts ]
 Crank Shaft Position Sensor
Post Crank Shaft Position Sensor
So my check engine light comes on briefly when I’m not giving it throttle but goes off as soon as I give her gas, so I’m pretty sure my crank shaft position sensor needs to be adjusted, but for the life of me I can’t find a “how to” or directions on how.
Just set the valve lash and all is well and running 10x better, just want to make sure everything is perfect.
Wed Nov 18, 2020 6:47 pm
Post Re: Crank Shaft Position Sensor
.030 between sensor and flywheel
Sent from my SM-G975U using Tapatalk
Wed Nov 18, 2020 9:22 pm
How do I actually get to it? Is it kinda a obvious thing, by removing the front cover around the flywheel?
Thu Nov 19, 2020 12:32 am
Sat Nov 21, 2020 4:54 pm
My book says .030, but I've had better performance with .015..
Mon Nov 23, 2020 11:14 am
