It is currently Fri Mar 29, 2024 9:31 am
[ 5 posts ] |
Crank Shaft Position Sensor
ducktank23
So my check engine light comes on briefly when I’m not giving it throttle but goes off as soon as I give her gas, so I’m pretty sure my crank shaft position sensor needs to be adjusted, but for the life of me I can’t find a “how to” or directions on how.
Just set the valve lash and all is well and running 10x better, just want to make sure everything is perfect.
Wed Nov 18, 2020 6:47 pm |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
Re: Crank Shaft Position Sensor
.030 between sensor and flywheel
Sent from my SM-G975U using Tapatalk
Wed Nov 18, 2020 9:22 pm |
ducktank23
How do I actually get to it? Is it kinda a obvious thing, by removing the front cover around the flywheel?
Thu Nov 19, 2020 12:32 am |
lastchance
Sat Nov 21, 2020 4:54 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
My book says .030, but I've had better performance with .015..
_________________ so many rivers, so little time
Mon Nov 23, 2020 11:14 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 336 guests |
