It is currently Tue Mar 17, 2026 4:02 am
[ 5 posts ] |
Crank Shaft Position Sensor
ducktank23
So my check engine light comes on briefly when I’m not giving it throttle but goes off as soon as I give her gas, so I’m pretty sure my crank shaft position sensor needs to be adjusted, but for the life of me I can’t find a “how to” or directions on how.
Just set the valve lash and all is well and running 10x better, just want to make sure everything is perfect.
| Wed Nov 18, 2020 6:47 pm |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
 Re: Crank Shaft Position Sensor
.030 between sensor and flywheel
Sent from my SM-G975U using Tapatalk
| Wed Nov 18, 2020 9:22 pm |
ducktank23
How do I actually get to it? Is it kinda a obvious thing, by removing the front cover around the flywheel?
| Thu Nov 19, 2020 12:32 am |
lastchance
| Sat Nov 21, 2020 4:54 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
My book says .030, but I've had better performance with .015..
_________________ so many rivers, so little time
| Mon Nov 23, 2020 11:14 am |
[ 5 posts ] |
