It is currently Sat Mar 21, 2026 4:05 am
Reply to topic  [ 5 posts ]
 BIG Honda motors?
Post BIG Honda motors?
What does Honda have coming up that's BIG?
40hp? More?
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Fri Feb 05, 2021 12:07 pm
Post Re: BIG Honda motors?
I wouldn't suggest holding your breath. Yamaha released some larger verticals a few years ago, but they weren't close to 1000cc, so they never got any interest. Honda seems pretty content in the "around 800cc" market, just like kawasaki and yamaha. Briggs is still your only factory mm engine horizontal big block option, and add kawasaki and kohler if you want to do it yourself.
#mudmotor>physics
Fri Feb 05, 2021 4:01 pm
Thanks, Russ. Out of curiosity, why do you say that about Kohler and Kawi?
Fri Feb 05, 2021 4:42 pm
You'd have to buy one and install yourself.
For the larger power market, mudmotor manufacturers only use the small block kohler (25 hp or whatever it is). Kawasaki used to cringe when they heard the word mudmotor. Mudbuddy tested the big kohler and said it didn't perform. I expect it performed similarly based on the dyno sheet, but cost more. Subaru made a big block for a little bit, then quit. Looked like a decent potential option. None of the larger displacement engines except briggs have aftermarket supported power recipes.
#mudmotor>physics
Fri Feb 05, 2021 6:17 pm
Sat Feb 06, 2021 9:24 pm
