It is currently Tue Mar 17, 2026 4:28 am
Reply to topic  [ 1 post ]
 Throttle screw and cable comes loose.
Post Throttle screw and cable comes loose.
So the mudbuddy throttle screw holding the cable somehow not holding the bracket causing the cable to move and high idle. Have stripped one screw replaced with new. Reset back to idle. Keeps happening though. I set it and sounds great idle. Then when I use it the cable comes loose again in the field. Engine revs off chart high. This is a console. How can you make this tighter? Bolts? Bigger screw?
Fri Jan 08, 2021 8:49 pm
