It is currently Thu Mar 28, 2024 1:23 pm
Reply to topic  [ 6 posts ]
 Replace the oil seal on a 35 without opening the case?
Post Replace the oil seal on a 35 without opening the case?
Can you replace the oil seal without opening the case?
Sun Mar 07, 2021 6:16 pm
Post Re: Replace the oil seal on a 35 without opening the case?
Yes. Sand that crank real smooth before installing the new seal.
#mudmotor>physics
Sun Mar 07, 2021 8:43 pm
Mon Mar 08, 2021 5:41 am
I wasn't all that careful, had the seal remover tool and just jerked it out of there. Going back on with the new one shouldn't take a ton of oil. Remember you have to wipe off the crank and put antiseize on
#mudmotor>physics
Mon Mar 08, 2021 8:02 am
Thanks Russ
Mon Mar 08, 2021 11:47 am
Sometimes they can be stuck and tough to remove.
Poke or drill a small pilot hole into the center of the old seal.
Thread in a #10 Sheetmetal screw.
Clamp with Visegrips and attach to a small slide hammer / jerking tool. (Available from Harbor Freight)
Give it a couple of bumps and it should come out readily easy.
If the Sheetmetal screw pulls out, put another hole opposite the 1st one and retry.
I've used this method several times on stubborn seals with good results.
Good luck and happy Knuckle Bust'in. :) :P
Wed Apr 28, 2021 5:34 pm
Users browsing this forum: No registered users and 265 guests
cron
