It is currently Fri Jan 30, 2026 2:23 am
Reply to topic  [ 3 posts ]
 help with throttle
Post help with throttle
ok so here's my issue . my boat runs great besides the freaking throttle is always sticking . Turning the throttle is a bitch and its stiff as ever . When I remove the bar that's inside the tiller handle its always gummy and that's why it sticks or won't hardly let me give it gas . What the hell should I do to correct this issue ? I've used oil ,and any other lube you can think of and the problem returns In about a month . im exhausted of dealing with this and need some ideas please. ps its a pro drive and thanks
Mon Aug 16, 2021 7:09 pm
Post Re: help with throttle
Sounds like the tubing is starting to fall apart. May just need to call prodrive and order a new cable.
Mon Aug 16, 2021 7:15 pm
There's rubber sleeves inside the tiller tube that sound like they need to be replaced. Call PD and they'll sell ya a pair.
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Tue Aug 31, 2021 6:56 pm
