37xd seems to run rich http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=75781 |
Author: | Riverman24 [ Thu Oct 21, 2021 6:32 pm ] |
Post subject: | 37xd seems to run rich |
Motor has seemed to be running rich it loads up sometimes and i can smell gas so I adjusted my valves and changed the plugs but nothing seemed to change |
Author: | Wchauvin [ Fri Oct 22, 2021 6:38 am ] |
Post subject: | Re: 37xd seems to run rich |
A freer flowing exhaust may help counteract that, depending on what exhaust you are running currently. |
Author: | Riverman24 [ Fri Oct 22, 2021 7:21 am ] |
Author: | Wchauvin [ Sat Oct 23, 2021 8:33 am ] |
Ooooo ok, check your fuel pump and make sure it is functioning correctly. Also, what size fuel line are you running? |
Author: | Riverman24 [ Mon Oct 25, 2021 5:47 pm ] |
Author: | Will C [ Tue Oct 26, 2021 2:37 pm ] |
i would first do a health check. leaking valves, popped headgasket or a flat cam can all do this. does the oil smell like gas? tanks can swell and shove fuel into engine through vent line on top of hi pressure pump . aside from that its commen these days to have the vent line on the high pressure pump leak fuel into throttle body when the needle dosent seal on the seat. the hi pres pump has a needle and seat just like a carburetor. u can remove the small vent line and install a longer line to exit below the engine. then u can see if and when the pump is flooding itself |
Author: | Riverman24 [ Thu Oct 28, 2021 3:43 pm ] |
Author: | Riverman24 [ Thu Oct 28, 2021 4:05 pm ] |
Author: | Will C [ Mon Nov 01, 2021 2:49 pm ] |
yessir it is |
Author: | Riverman24 [ Wed Nov 10, 2021 1:51 am ] |
