hunter272727
Broken Shaft?
What would cause the shaft in the lower unit to break like this? This is the second lower unit I've replaced and they aint cheap.
Thu Feb 04, 2010 10:36 am |
GaugeTheDuckDog
Re: Broken Shaft?
What type of motor?
_________________ 18x60 GTB 35 GTRrrrr
Thu Feb 04, 2010 10:57 am |
hunter272727
Re: Broken Shaft?
2007 ProDrive
Thu Feb 04, 2010 12:36 pm |
caddobrook
Re: Broken Shaft?
I would call kp at prodrive and discuss with him. He is very helpful and can help you sort it out.
I have called him on a number of issues, and he is always helpful.
Don't know if you have had the motor since 2007 or got it later, but either way you shouldn't be snapping the shafts.
KP will get you sorted out...
Let us know what happens....
Thu Feb 04, 2010 1:34 pm |
hunter272727
Re: Broken Shaft?
Thu Feb 04, 2010 2:54 pm |
JIMMY W
Re: Broken Shaft?
That Sucks!!ProDrive don't know what the problem is with the Gearboxes?
Thu Feb 04, 2010 6:31 pm |
craig
Re: Broken Shaft?
Thu Feb 04, 2010 6:35 pm |
caddobrook
Re: Broken Shaft?
Yeah, what kind of feedback did he give you on why it may be happening?
I would figure out the core problem before I kept sinking money in the shafts...
It's not normal....
What were you doing when it snapped?
Thu Feb 04, 2010 6:45 pm |
sea-n-spots
Joined: Wed Jul 15, 2009 4:50 pm Posts: 75 Location: La
Re: Broken Shaft?
You stated "The new one has a bigger nuckle, so I assume bigger gears". Looking at the pictures you provided, I think that I can see a tag that is installed with four (4) rivits into the gear housing itself. If so, that is one of the old gear boxes; the new ones have the word "Prodrive" casted onto both sides of the gear housing itself. The other way to tell for sure is if there is a bearing atop of the gear that is broke off;I cannot tell from the pictures, it's on the opposite side of the broken shaft side. I ask because around that time frame (07-08) the gear boxes were up-graded. The newer ones have more "Robust" gears and incorperate an additional bearing in the design. The driven gear is supported on both sides, unlike the "older" ones that were supported below only. Now with opposing angular contact bearings, one above the drive gear and one below; the driven gear is better protected from bi-axial thrust loads, and prevent the driven gear from flexing in the area where the drive shaft is pressed into the driven gear, thus breaking the drive shaft just below the driven gear.
If that is one of the "new" ones, it's the first I see broke.
Also looking at the break, did by chance you hit anything rather hard that you can remember?? That triangular "sliver" above the shaft key (in the broken gear), is indicative with rototaional force, and the fact that the break is on plain with the bottom of the key, looks like possible impact.
Just my opinion.
_________________ 1648 PD w/36FPR
Thu Feb 04, 2010 7:30 pm |
dead animal
Re: Broken Shaft?
i'm thinking u knocked the fuck out of sumthing and halfway broke the shaft, then kept running it till it finished breaking. if that's not the first one u have broken, i would tend to lean that way.
nothing is indestrucable.
or could be a monday morning motor.
either way, gonna cost a few dollars to fix.
good luck.
Thu Feb 04, 2010 8:26 pm |
dead animal
Re: Broken Shaft?
Thu Feb 04, 2010 8:31 pm |
BROOKS
Joined: Tue Jan 13, 2009 9:46 pm Posts: 4596 Location: East TEXAN Proud
Re: Broken Shaft?
Basically ~ I'm gonna leave this one alone and chalk it up as ..... Thangs Brake when yore doin' tha deal !!!!! I will add this tho ...... belts take 'bout 15 minutes to replace ifin' you have too !!!!!!
_________________ Git a Gator-Tail or ride in mines wake ...... MtrFact !!!!! '05 Model .... Still Number One on the Water !!!!
Thu Feb 04, 2010 8:47 pm |
craig
Re: Broken Shaft?
Thu Feb 04, 2010 9:09 pm |
craig
Re: Broken Shaft?
Thu Feb 04, 2010 9:12 pm |
deltaduckmaster
Re: Broken Shaft?
Da usally when these ???? are behind a statment its called a Question!!! That is what Jimmy was asking!!! If they know what was causing the problem By the way jack azz how many have you broke!! And yes a belt takes 15 minutes to change!! and the belt is under 100$$ So this is gonna cost this feller 1000$$ to replace it and dam the second one!!
Thu Feb 04, 2010 9:16 pm |
POKER1
Re: Broken Shaft?
Who knows why it broke. Probably because at some point he knocked the chit out of something. When my prop shaft broke (07 model) I was running clean water but it had obviously been cracked prior from hitting something and took awhile to completely break. And yeh 500.00 for a complete lower unit is more than a 100.00 but you not gonna get around breaking chit on any of these things. Its the nature of the beast with the product you bought. A LU can be changed out in 30 minutes too.
Thu Feb 04, 2010 9:31 pm |
JIMMY W
Re: Broken Shaft?
Thu Feb 04, 2010 9:52 pm |
deadbird8
Re: Broken Shaft?
Fri Feb 05, 2010 6:51 am |
craig
Re: Broken Shaft?
Fri Feb 05, 2010 7:03 am |
MaXXis85
Re: Broken Shaft?
I bet if that shaft is made out of 300M it wont break LOL. But you think its expensive now for a LU imagine all the parts being some Badass material. Good luck with your repair dude.
Fri Feb 05, 2010 8:22 am |
dead animal
Re: Broken Shaft?
Fri Feb 05, 2010 9:06 am |
dead animal
Re: Broken Shaft?
i realize that mudbuddy cloned gatortail, but i'll be damned if the gatortail internet rescue team don't sound like leaky, mud doctor, almo, and the rest of the mb team.
lets all go to utah on sunday and wirship the phoobah!!!!!!!
Fri Feb 05, 2010 9:10 am |
hunter272727
Re: Broken Shaft?
I didn't hit anything out of the norm that day. Maybe from the hard bottom I was hittin the day before. To clear things up that is a 07 LU in the pic. The new one I replaced it with is upgraded/current one.
Fri Feb 05, 2010 1:12 pm |
caddobrook
Re: Broken Shaft?
Did KP give you any idea what caused the problem?
I would really spend some time and energy troubleshooting that before I kept spending money on new shafts...
Just curious-
I have two prodrives and don't want to find myself in your shoes.
Good luck, and thanks for updating us...
Fri Feb 05, 2010 1:31 pm |
MaXXis85
Re: Broken Shaft?
Really it sucks to break. But really if you use your motor hard regardless of brand some things are going to break.
I see it alot because I am into 4x4's aswell and your breaking something or changing a bad part before it fails all the time. Its part of the game. The besat way to not have the problems is to not ever buy a toy...
Fri Feb 05, 2010 2:47 pm |
sea-n-spots
Re: Broken Shaft?
Fri Feb 05, 2010 6:01 pm |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
Re: Broken Shaft?
Damn, melted plastic covers...broken shafts....smoked clutches... GLAD I BOUGHT A GODEVIL. Carry on. PS. Sorry for stirrin the pot but this $hit is funny as hell.
Fri Feb 05, 2010 9:30 pm |
