DMC
Joined: Sun Jan 25, 2009 7:23 pm Posts: 204 Location: Bayou House!
35 briggs cam
Is there anyone out there that is grinding cams from a new core and not a welded up job? Does anyone offer rocker arms with increased ratios over stock that are reliable? Thanks
Thu Feb 04, 2010 2:29 pm |
craig
Re: 35 briggs cam
EVT.
Thu Feb 04, 2010 2:42 pm |
DMC
Re: 35 briggs cam
Thanks Craig, I was under the assumption that EVT had welded cams. I'll look into it.
Thu Feb 04, 2010 3:03 pm |
craig
Re: 35 briggs cam
They did at one time. Not sure if they still do or not.
Thu Feb 04, 2010 3:05 pm |
gecker
Re: 35 briggs cam
There are no "un-ground" cores available at this time so everything has to be welded. If Briggs could or would supply us with an unground core like they do on the various kart racing engines, we would not need to weld them.
If they are welded correctly and then heat treated, there is no issues with a welded cam core at all. We have had zero failures in at least 15 years on any engine type with a welded core regardless of RPM or HP.
Fri Feb 05, 2010 5:19 am |
bigdtex
Re: 35 briggs cam
Do you have a small block cam available for the 23?
_________________ Boatless for now HRCH UH "Homer" MH (500 Point Club) HRCH "Streak" MH QAA
Fri Feb 05, 2010 6:25 am |
woffman
Joined: Tue Jan 13, 2009 6:35 pm Posts: 208 Location: WI
Re: 35 briggs cam
I think BPS does now, but I'm not sure. I thought that was the "new" cam that was in mine.
Fri Feb 05, 2010 6:37 am |
deadbird8
Re: 35 briggs cam
Fri Feb 05, 2010 6:52 am |
drake1
Re: 35 briggs cam
Our new cams are not welded they are ground. We have also repaired some stock flat cams by using a spray process to apply metal rather than welding them. Our new cams are making more torque and better throttle response than the older cheetah cam. We also have higher ratio rocker arms as well.
Fri Feb 05, 2010 8:21 am |
DMC
Re: 35 briggs cam
Thanks for all the replies!
Fri Feb 05, 2010 5:28 pm |
