| Engine swap wiring question GTR http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=75885 |
| Author: | douchepickle [ Sun Mar 06, 2022 11:11 am ] |
| Post subject: | Engine swap wiring question GTR |
Bought a new 35hp carb vanguard engine to replace my 25 Subaru efi on my 2013 GTR. Going to remove the key switch wiring from the engine to the tiller handle key switch wiring. There is a brown and grey wire on the new engine. I assume the brown is the key switch ground. What is the grey? On the GTR the grey is clutch but this grey is in the new engine harness. No idea what to do with this wire. On the new engine connector from key switch: Brown - ???? Grey - ???? Yellow - starter B+ Black - coil ground Red - terminates at the connector Green - oil pressure switch On GTR tiller handle from key switch: Yellow - starter B+ Orange - starter B+ Black - coil ground Red/white - fuel pump (efi only) |
| Author: | bluesky2012 [ Tue Mar 08, 2022 9:43 am ] |
| Post subject: | Re: Engine swap wiring question GTR |
If you don’t have it figured out, I’ll try and swing by my storage unit and look on my boat sometime over the next few days. Sent from my iPhone using Tapatalk |
| Author: | Will C [ Tue Mar 08, 2022 11:34 am ] |
grey is a key on 12v |
| Author: | douchepickle [ Tue Mar 08, 2022 5:34 pm ] |
Thanks guys. Got confirmation today that grey is for a fuel solenoid. Not needed for my application. 1 step closer to having this thing back in the water. |
| Author: | douchepickle [ Wed Mar 09, 2022 6:47 pm ] |
Wired up. 12v to lug on starter. And nothing when I hit the key. Trim works and key box on tiller was never taken apart. Orange wire is on starter lug with batt+. Yellow wire is on solenoid. Wtf |
| Author: | douchepickle [ Wed Mar 09, 2022 8:47 pm ] |
Found a broken wire n the harness. |
