It is currently Sat Nov 14, 2026 5:36 am
[ 6 posts ] |
Engine swap wiring question GTR
douchepickle
Joined: Fri Feb 13, 2009 9:24 pm Posts: 204 Location: GA missing the delta
Bought a new 35hp carb vanguard engine to replace my 25 Subaru efi on my 2013 GTR.
Going to remove the key switch wiring from the engine to the tiller handle key switch wiring. There is a brown and grey wire on the new engine. I assume the brown is the key switch ground.
What is the grey? On the GTR the grey is clutch but this grey is in the new engine harness. No idea what to do with this wire.
On the new engine connector from key switch: Brown - ???? Grey - ???? Yellow - starter B+ Black - coil ground Red - terminates at the connector Green - oil pressure switch
On GTR tiller handle from key switch: Yellow - starter B+ Orange - starter B+ Black - coil ground Red/white - fuel pump (efi only)
_________________ 1652 modV 35GTR
| Sun Mar 06, 2022 11:11 am |
bluesky2012
 Re: Engine swap wiring question GTR
If you don’t have it figured out, I’ll try and swing by my storage unit and look on my boat sometime over the next few days.
| Tue Mar 08, 2022 9:43 am |
Will C
grey is a key on 12v
| Tue Mar 08, 2022 11:34 am |
douchepickle
Thanks guys. Got confirmation today that grey is for a fuel solenoid. Not needed for my application. 1 step closer to having this thing back in the water.
| Tue Mar 08, 2022 5:34 pm |
douchepickle
Wired up. 12v to lug on starter. And nothing when I hit the key.
Trim works and key box on tiller was never taken apart. Orange wire is on starter lug with batt+. Yellow wire is on solenoid. Wtf
| Wed Mar 09, 2022 6:47 pm |
douchepickle
Found a broken wire n the harness.
| Wed Mar 09, 2022 8:47 pm |
[ 6 posts ] |
